1971 Inside door handle
Old Aug 19, 2025 | 07:58 PM
peyc2's Avatar
peyc2
Default 1971 Inside door handle
Hello,
For whatever reason, I am having a devil of a time fitting the inside door handle into my drivers door mechanism.
What's the best trick to get the mechanism popped out, so you can slide the handle into the door unit?
I have tried screw drivers, or a pliers, but they get in the way of sliding the handle into the opener?
thank you,
Old Aug 19, 2025 | 09:48 PM
litevette's Avatar
litevette
You can remove the door panel if it comes down to that.
Old Aug 19, 2025 | 11:38 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
No tips except to be careful prying on the pot metal bits of the handle mount as you can break the edges of the piece the handle slides into.
Old Aug 20, 2025 | 02:53 AM
Eliredandblack's Avatar
Eliredandblack
First place the door card on the door. Next I pull on the door handle gently (open) with a large blade screwdriver, then insert a LARGE BLADE screwdriver into the pot metal receiver to keep it extended. The placement of the screwdriver is critical, because the pot metal is very very very fragile. Next slowly remove the screwdriver, as the door handle is slid on.
Old Aug 21, 2025 | 10:02 PM
socal_tom's Avatar
socal_tom
I just used a long screw driver and it worked easy
To 1971 Inside door handle
