Daveinspain
Obsessed
close
After lots of hard work, trying to get the old clutch assembly off, I successfully installed the new clutch assembly. It worked fine but unfortunately oil came spraying out from the compressor shaft so I need a new compressor. I found a 1970 air compressor on eBay but not sure if I should risk getting that one or buying a refurbished period correct compressor. Does anyone know the correct part number for a 71 AC compressor?
Quote:
I have 2 compressors from a 72 I'll sell if you want one. PM me. I'll check on the cost but I think I paid $500 for the reman and the other is off my car. Both are for R134 and have the clutch on them. I ended up going with a SandenOriginally Posted by Daveinspain
Quote:
If you wanted to mess with it, you might just need a new seal. I posted a how-to on the process years ago with part numbers and tool IDsOriginally Posted by Daveinspain
https://www.corvetteforum.com/forums...l-replacement.
Edit - not sue why the above link doesn't work anymore, but I've attached a PDF of it
Quote:
Sent you a PMOriginally Posted by Daveinspain
