Clunk when shifting into gear
Old Oct 4, 2025 | 12:19 PM
skookumchuck's Avatar
skookumchuck
Default Clunk when shifting into gear
Hi knowledgable ones,
I have a '76 with the 350 and TH350 transmission. It runs very well, but recently there has been a noticeable clunk when shifting into gear, either reverse or drive. Could this be a transmission issue, driveline, U-joints or rear end? I went for a short cruise yesterday, and I did not notice any shifting problems under normal driving even when I jumped on the freeway and opened it up a bit. Any insights will be greatly appreciated. I'm mechanically challenged, so please be gentle.
Old Oct 4, 2025 | 12:29 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
My '72 TH400 has done this as long as I've had it. How hard it engages seems dependent on idle speed, but even at low idle it seems to thunk and squat at times. In the last 5 years, I've had the trans rebuilt, installed new driveshaft u-joints and new differential snubber cushions. Still does it. I've not rebuilt the differential or changed axle u-joints, but I'd think if there was that much backlash and slop it would reveal itself with other problems, which there aren't. @GTR1999 Gary?
Old Oct 4, 2025 | 12:33 PM
Bikespace's Avatar
Bikespace
For the OP, I'd do the snubber bushing first.
For you, I'd check your idle speed, vacuum connection to the trans, and the vacuum modulator (unit, and adjustment).
Old Oct 4, 2025 | 12:59 PM
Laughing Coyote's Avatar
Laughing Coyote
Veteran: National Guard
I agree on the differential front snubber bushings. Mine were just about gone and I had a clunk when putting it in gear, but drove and shifted fine. After changing it out, no more clunk.
Old Oct 4, 2025 | 01:05 PM
barkingrats
Idle speed in D is ~600, trans shop checked the modulator and said it's fine, 2nd and 3rd shifts feel smooth and uneventful. I can certainly check vacuum to it and play with adjustment.
Old Oct 4, 2025 | 01:28 PM
skookumchuck
Thank you for your insights. Is replacing the snubber bushings in the differential an expensive fix? I know that's relative; what's expensive? I have no experience inside a transmission or differential, nor do I possess a lift, so I would have to take the car to a transmission shop. Any ball park guesses on the cost of this replacement? Sounds like the rubber bushing kit is the way to go. Fast forward: after doing a little research, I discovered the bushing kit is only $20. or $30., and maybe a hundred bucks for a shop to put it in. Thanks again.
Old Oct 4, 2025 | 02:04 PM
barkingrats
Shouldn't be but an hour of shop time.
Old Oct 4, 2025 | 06:57 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
Snubber Bushing
To Clunk when shifting into gear
