1968 Wipers
Old Oct 22, 2025 | 06:28 PM
Jonscazz's Avatar
Jonscazz
Default 1968 Wipers
Recently blew a wiper motor up in February. Replaced and whole system worked.
A couple weeks ago the wipers did not work. I am not getting signal voltage on brown wire at wiper motor.
According to manufacturer, I cannot bench test the motor or I’ll void warranty of motor.
I bought a new motor from corvette central today and installed it. I am still not getting any voltage on brown wire with wipers on.
Wiper motor ground, wiper switch ground, override switch ground, and both grounds on relay are good.
Relay clicks with 12V applied. I took it apart and it moves with voltage applied. (I did the Wilcox test).
Wiper switch passed Wilcox test too.
I am starting to think my second motor is also bad? I noted the blue wire on the motor was not ground with wiper switch on low. Anything I’m missing?
Old Oct 22, 2025 | 07:42 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
If it has a warranty send it back and get a new one. If not do the bench test with it in the car. Its in the willcox video for the 68
Old Oct 22, 2025 | 08:17 PM
Jonscazz's Avatar
Jonscazz
Update:
The light blue wire at the wiper motor is grounded with wiper switch on low and ignition OFF.
However, ignition switch ON and wiper switch on low, the light blue wire loses its ground. It still has no ground when I unplug the wiper relay.
For the wiper to activate (like in Wilcox video mentioned above)…the light blue and green wires need to be grounded. I am not sure where to look to trace the problem.
Ignition off/wiper low = grounded
ignition on/ wiper low = not grounded.
Green wire keeps its ground whether ignition is on or off.
EDIT: Fixed a ground to light blue. Green was grounded. Ignition on. Yellow and red wires to motor had 12V. Nothing.
Has anyone had issues with these motors? I’m surprised two have failed on me.
Old Oct 22, 2025 | 09:54 PM
socal_tom's Avatar
socal_tom
Fixing my wipers is very challenging I keep hitting a dead end but I still have hope
Old Oct 23, 2025 | 12:12 PM
Jonscazz's Avatar
Jonscazz
Is there an issue if you install the wipers in park position?
Old Oct 23, 2025 | 01:57 PM
Rescue Rogers
Its in the AIM, the damage would be from the wipers hitting each other and would probably do more damage to the arms and linkage than to the motor. During testing you need to spray water in the windshield so the blades slip enough for the motor to park correctly
Old Oct 23, 2025 | 01:58 PM
Jonscazz's Avatar
Jonscazz
Thank you. If you ran the wiper motor without the linkage connected would that cause an issue?
Old Oct 23, 2025 | 02:10 PM
Rescue Rogers
It may not park correctly but it wont hurt anything. I have done plenty of bench tests with nothing connected and never had an issue
Old Oct 23, 2025 | 02:22 PM
Jonscazz's Avatar
Jonscazz
Lectric Limited is claiming I didn’t follow steps in the assembly manual and I should not install wipers on motor while wipers in park. I’m not sure what I’m missing here. My first motor was installed with wipers in park and it worked.
To 1968 Wipers
