The mufflers I have on my 76 now are just a bit too loud for me. When I crank it, the initial sound will wake up the neighbors. I would like some that have a little rumble but not much. I know when I buy some I'm stuck with them. Anyone know which ones I would need to accomplish what I'm wanting? And some that don't break the bank also. Thanks!
I forget where, but I once saw where one of the vendors (maybe Flowmaster) had little clips of what each one sounded like. How acurate that would be though may be iffy. I guess it would depend on what you are listening on (speakers, headphones) and the volume. I would expect to lose a few ponies though. Typically, the free flowing stuff is louder and the more restrictive stuff is quieter.
EDIT: Not sure if any of this will help..
You didn't post what kind of mufflers you currently have, whether you have 2 or 2.5", dual or not, rams horns or headers, etc. so hard to know where you are coming from... ?
C8H18: At work right now so not sure what the pipe size is, but it's stock dual exhaust except for the mufflers and I don't know what brand they are. Just purchased the car.
here is my thread with help i got with sound and videos Dynomax Walmart Super Turbo. I get compliments on the tone being just right..not too loud or obnoxious.
I also recommend the clamps in the thread. The OEM crush type clamps make it VERY hard to remove and work on car. and a i use a small amount of Never Seize.
Before I switched to the Ultraflo's I had the Dynomax super turbo's on the car for about 30yrs. they sound good. louder than stock but definitely not obnoxious.
Pat
Originally Posted by ALLEN007
Good info, thanks!
Factory pipe size in '76 was 2 1/4" with two Y-pipes, not a true dual system...
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Buy a TOYOTA ............... a VETTE should RUMBLE & GROWL, even with only 180 hp or if your lucky enough to have an L-82 with 210hp !!!
