Hi folks, I’m new to the forum and thought I’d post my issue here after trying my luck on Facebook.
I recently acquired this 1968 327 with a telescopic steering wheel. The previous owner had an aftermarket steering wheel on it, so I decided to replace it with the original one.
However, after reinstalling everything using Jim Shea’s Corvette steering papers, I’m left with this issue. Any knowledgeable folks here who can point out what’s wrong and what needs to be done?
Please view the video I have uploaded on Youtube by clicking here:
If I understood the post correctly, the thread starter had the same issue as I did, and the upper bearing was the problem — the bearing not attaching to the part below the steering wheel hub?
sorry yes ignore my first reply i completely did not see what was happening in your video. i don't think there is any actual upper bearing retainer on the 68, its more or less peened into place. from Jim Shea's paper this is the part relevant to you
Replace or Repair Upper Column Bearing
The bearing that is part of the upper bearing housing #4 was not designed to be serviced. It was a press fit into the die casting and there was a thin lip on the housing bore that was staked or spun over to retain the bearing. The bearing has been known to come loose. If this is the problem that you are correcting, you can try to epoxy glue the bearing case into the housing bore. You can also attempt to carefully peen limited areas of the case over on the bearing.
thinking back on my car now, i believe i tried to peen the edges and it did not work, i ended up using a little bit of jb weld to hold the bearing in place
Based on the fact that the 68 has a press-fit bearing into the die casting, I believe it cannot be replaced or serviced?
"Replace or Repair Upper Column Bearing
The bearing that is part of the upper bearing housing #4 was not designed to be serviced. It was a press fit into the die casting and there was a thin lip on the housing bore that was staked or spun over to retain the bearing. The bearing has been known to come loose. If this is the problem that you are correcting, you can try to epoxy glue the bearing case into the housing bore. You can also attempt to carefully peen limited areas of the case over on the bearing."
So what you are saying is that the silver bearing you see on the video should be glued to the hub?
yes, assuming it is still good. it looks like it pulled out of the hub. common after years as there is no retainer. mine would just pop right back in with proper alignment. play around with it figure out how to get it to pop back in, then just get some epoxy to glue it to hub and pop it in let it sit
So basically, I can remove the steering wheel, realign the hub, press it firmly onto the bearing, then install the washer and nut — and just hope it works? I mean, I only had to reinstall the steering wheel after realizing the washer was missing before the nut. It was working perfectly fine before that... I guess I’m just unlucky.
No you need to affix the bearing race back into the retainer. Original it was pressed and peened over. Now it pulled out. You need to epoxy it back in place or drill and tap for set screw or find a good used one. Standard and tele column used the same one. And so did Corviars
When I rebuilt my 68 tele, I peened the top of the die casting over the bearing with a punch in 3 or 4 places. Lots of ways to do this. Also followed Jim Shea's papers, the only and excellent source I know of. 68 tele's are one year only and hard to find and expensive when you do find one as you know. Hope I find another one day.
IMHO: "I guess I’m just unlucky." No; just typical C3 experience I would say, LOL's!
Sounds like a decent way to fix the issue. I suppose if I ever need to replace the column, I would have to opt for an aftermarket one - or isn't that an alternative, given that the '68 column is different from all the other years?
