1973 Corvette Rolling Chassis Help
Old Nov 10, 2025 | 02:11 PM
VetteZilla604's Avatar
VetteZilla604
5th Gear
Default 1973 Corvette Rolling Chassis Help
Hi Everyone,
New to the forum and seeking some help to figure out what my corvette is worth. Long story short, it was my dads and unfortunately he passed away. Looking to sell it for a reasonable price as it's taking up space and i need room for other projects. Any advice would be greatly appreciated. I'm not sure if it has the L82 engine or not. Everything in the pictures would be included.
Thanks!
Old Nov 10, 2025 | 03:38 PM
Piersonpie's Avatar
Piersonpie
In restored condition, painted or powder coated with all new bushings, and new tires I’ve seen them go for up to 10. That’s without an engine or transmission though.
I would assess the condition of the frame rails and rear kickup area. It’s the area that’s most prominent to rusting out. If it’s good, and with everything else I’d say you could get 5 for it easily.
Old Nov 10, 2025 | 04:01 PM
69L88's Avatar
69L88
Shoot a pic of the engine stampings on the right side (forward) of the block.
Shoot a pic of the underside of the differential, focusing on the aft most area, where the cover attaches.
Old Nov 10, 2025 | 08:34 PM
VetteZilla604
5th Gear
I would asses the condition of the frame rails and rear kickup area. It’s the area that’s most prominent to rusting out. If it’s good, and with everything else I’d say you could get 5 for it easily.
Thanks, much appreciated
Old Nov 10, 2025 | 08:36 PM
VetteZilla604
5th Gear
ok i'll see if i can find those, thanks
Old Nov 10, 2025 | 09:19 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
A 73 bare frame should fit any C3 from 68 to 74 pretty easily.
And the 68-72 chrome bumper year cars are in more demand than other years of the C3.
A brand new frame can be bought for around 5 grand. Up to 7 grand now
So a good used one should be worth part of that.
But it would need to be straight and free of rust holes.
Check carefully, especially on the lower frame in front of the rear kickup.
See the forum thread on how to check for rust.
Run some pics by us.
Then post it for sale in the For Sale thread.
It should move. Maybe not right away, but someone will need one.
It is a frame for an automatic. That means it has a removeable center crossmember.
It will still fit a manual car.
I zoomed in pretty close, and I saw only mild surface rust, so that is a very good sign.
Mine had much more pitting than that and it was still solid.
What happened to the body?
Old Nov 12, 2025 | 12:31 PM
zxryder72's Avatar
zxryder72
Look for stamps on the pad just below front of passenger side cylinder head. The CLR here is the engine code, 1973 L82 manual trans. If you can find yours compare to the list. (I attached the 1973 list here.)
Also, VIN number is stamped in two places on the top of frame on the driver's side. One near the door and one back by the rear tire. The stamps are not deep and can be rusted over and hard to read but they should be there. For a '73, there is a single-digit engine code included in the VIN.
Old Nov 12, 2025 | 07:05 PM
VetteZilla604
5th Gear
I should have time to get more pictures over the weekend
Old Nov 12, 2025 | 08:42 PM
69L88's Avatar
69L88
Shoot a couple from the backside of the block.
Old Nov 17, 2025 | 07:11 PM
VetteZilla604
5th Gear
I found these numbers
Old Nov 17, 2025 | 08:23 PM
zxryder72's Avatar
zxryder72
I found some info about a similar engine stamp that could help:
Old Nov 20, 2025 | 08:36 AM
Rebelyell's Avatar
Rebelyell
Hi Everyone,
Thanks!
Condolences on loss of your Dad.
Is this car's body available ? Do you know where this car's body is located ?
To 1973 Corvette Rolling Chassis Help
