Stuck in 2nd
Old Nov 15, 2025 | 06:58 PM
Scooter1974's Avatar
Scooter1974
6th Gear
Default Stuck in 2nd
Went to Supermarket and when I went to leave I noticed when I went to back out my car stalled, upon further review I noticed I could not get the car in any gear, but when I let the clutch out the car is in 2nd gear, so I got the car home, anyone have any ideas on what wrong
Old Nov 15, 2025 | 07:47 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
What's wrong? Obviously, your transmission is stuck in second gear!
You need to get underneath it and have a look see.
Are all 3 shift levers on the side of the transmission perfectly vertical? If yes. You should be in neutral. If they are and your not neutral. Your issue could be inside the transmission if all the nuts holding the levers are tight.
If there not. As in the 1-2 shift lever is pulled into second. But the shifter in the car is in neutral. The issue is with the shifter or rods.
Or perhaps the nut on the shaft of the 1-2 shift lever has come loose. Allowing the lever to move without actually moving the shaft. Thus the lever could be vertical but not engaged on the flats of the shaft. Leaving the transmission in second.
get under her and have a looky see.
Old Nov 15, 2025 | 09:08 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
Good luck solving the problem.
Old Nov 16, 2025 | 04:53 AM
Eliredandblack's Avatar
Eliredandblack
Check to see if the shifter arms are held on with “G Clips” and not cotter pins. On my 73 the cotter pins (someone installed) let the shifter arms flop around, and on one occasion caused the shifter to get stuck in one gear. I replaced some of the cotter pins and also the long pin that allows you to get into reverse, and the problem went away.
Old Nov 16, 2025 | 10:32 AM
Scooter1974
6th Gear
Nothing loose, definitely in 2nd, lever is not vertical, any other checks before I get someone to look at transmission ?
Old Nov 16, 2025 | 10:33 AM
sunflower 1972's Avatar
sunflower 1972
https://www.google.com/search?q=c3+c...h=503&dpr=1.67
Old Nov 16, 2025 | 11:09 AM
MelWff's Avatar
MelWff
With the shifter in neutral the 1/2 and 3/4 levers should be straight up and reverse lever should be forward. Loosen the 1/2 lever bolt and make sure the transmission gear shaft is straight up then tighten lever.
Old Nov 16, 2025 | 10:36 PM
firstgenaddict's Avatar
firstgenaddict
Sounds like a bent gate on the shifter body.
You should be able to get under the car and put an adjustable wrench on the lever on the side of the trans and move the lever back to a neutral position.
Old Nov 17, 2025 | 10:35 AM
gccch's Avatar
gccch
I had this problem recently. I could shift into reverse, but not down and over as it was stuck in 2nd if not in reverse. I was stranded late at night. Put a post up here and did a search and quickly found I needed to get underneath and move the levers vertical. I was able to get it up on a curb and shift one lever by hand which put me back in business. I have a brand new replacement repop shifter which was professionally installed.
Old Nov 21, 2025 | 06:25 PM
Scooter1974
6th Gear
Thanks everyone for all the reply’s , going to work on it this weekend, will just you updated on progress
Old Nov 29, 2025 | 05:35 PM
Scooter1974
6th Gear
Thanks everyone, change the shifter and linkage out and back on the road again!!!!!!
Old Nov 29, 2025 | 09:10 PM
4-vettes's Avatar
4-vettes
Always good to hear a success story!
Old Nov 29, 2025 | 10:22 PM
TKX 5-SPEED C3
Yay!
To Stuck in 2nd
