78 Speedometer/odometer repair?
Old Dec 23, 2025 | 07:24 PM
a kungfu mastah's Avatar
a kungfu mastah
Default 78 Speedometer/odometer repair?
I got door alignment all good so I was putting Speedo back in, and the itty bitty pin that the needle goes into broke :<
Is there anyone that does speedometer repair for 78? Or other cars that used the same assembly?
hie screwed am I?
Old Dec 24, 2025 | 02:30 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
For a 1976 Corvette speedometer, you can find main parts like the speedometer assembly/gauge, speedometer cable, odometer gears, bezels, and circuit boards from specialists like Zip Corvette, Corvette Central, or eBay, with options for new, rebuilt, or used parts to fix issues from simple cable wear to full gauge cluster restoration. Common repairs involve replacing the cable, recalibrating gears, or replacing the entire unit for accuracy.
Old Dec 24, 2025 | 09:27 AM
righthanddrive's Avatar
righthanddrive
Do a Google search for ' speedometer repair near me ' and then make phones calls to them about your problem.
Another option is to change to digital gauges ( which I did ). There are a couple of suppliers , one of them being much more expensive than the other. I bought the lesser expensive one back in 2007 and it has performed flawlessly.
Ed
Old Dec 24, 2025 | 09:29 AM
sunflower 1972's Avatar
sunflower 1972
hie screwed am I?
A lot of our C1 - C2 members use DeLuxe. https://deluxespeedometer.com/
Old Dec 24, 2025 | 06:22 PM
a kungfu mastah
Thanks I will give deluxe a call.
Old Dec 30, 2025 | 09:37 AM
a kungfu mastah
Just quick update, deluxe said they should be able to fix. Seem like a pretty good outfit
To 78 Speedometer/odometer repair?
