Best pump for differential fluid
Old Apr 4, 2026 | 11:15 PM
Joey_SS's Avatar
Joey_SS
Default Best pump for differential fluid
What do you guys like to use for draining and refilling your differential? I used a turkey baster with some clear 1/4" tubing. It was super slow and messy.
I tried refilling with 1/4" tubing and shoving the bottle above my exhaust pipes. But it took forever. Just easier to pour straight out the bottle.
Old Apr 4, 2026 | 11:39 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I use a large syringe. And for filling I use an old dish soap bottle with a short hose attached. But not so short that if it became unattached from the bottle it could be lost inside.
Old Apr 5, 2026 | 01:32 AM
carriljc's Avatar
carriljc
Joey_SS
You drill and tap for a drain plug. You can see where whomever installed mine ages ago did it.
https://www.corvetteforum.com/forums...post1605371430
Old Apr 5, 2026 | 07:42 AM
Golfobsessed's Avatar
Golfobsessed
Purchased this one from Amazon and it worked well for removing old diff fluid and filling both diff and trans, I wouldn't call it fast but it did work well.
Old Apr 5, 2026 | 10:21 AM
sphil's Avatar
sphil
I use this:
Old Apr 5, 2026 | 11:29 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I've used a regular fluid suction gun to pull out the old and usually just use the squeeze bottles the oil comes in to put it back in. I suppose you could use the same suction gun if you cleaned it or get two of them: a dedicated pull and a dedicated push. This holds a large amount of fluid, so it would be pretty quick.
Old Apr 5, 2026 | 11:41 AM
1Hotrodz's Avatar
1Hotrodz
There is a hand pump that screws on to a 1 Gal. container. No mess. Comes with a 18" clear plastic hose. The hose has a clip on the end of it to keep it from falling out of the Diff. hole.
To Best pump for differential fluid
