C3 Needle Bounce
Old Apr 23, 2026 | 08:51 AM
tferr92879's Avatar
tferr92879
8th Gear
Default C3 Needle Bounce
Before I replace this speedo, I figure I'd ask if anyone has solved this issue. My '69 original speedo bounces intermittently. I captured this yesterday.
Old Apr 23, 2026 | 09:42 AM
blk79nj's Avatar
blk79nj
i would start by lubricating the cable. They will bind, then release causing it to bounce.
Old Apr 23, 2026 | 09:44 AM
MelWff's Avatar
MelWff
I would also examine the driven gear in the transmission
Old Apr 23, 2026 | 10:56 AM
sunflower 1972's Avatar
sunflower 1972
https://youtube.com/shorts/QgKMbLfU91w
I wouldn't replace it, I'd have the original refurbished. https://deluxespeedometer.com/
Old Apr 23, 2026 | 11:42 AM
tferr92879's Avatar
tferr92879
8th Gear
The driven gear is brand new, although, I did get the set from Amazon, so there's a good chance it's bad.
Old Apr 24, 2026 | 06:24 AM
sleepchamber's Avatar
sleepchamber
Mine does the same intermittently but also has an intermittent sound to go with it. I also have a new driven gear on the trans side. I've experienced this in past cars where the cable was easier to remove. Greasing the cable on those never made any difference. I've just been living with it in my 72.
Old Apr 28, 2026 | 11:24 AM
Zanny1's Avatar
Zanny1
Annoying as heck. Try loosening the cable nut at the speedo and see if it helps.
Replaced the cable in my C2 speedo some years back and it was too long. By relaxing the nut, the bounce disappeared.
Just a suggestion. You can always loosen the cable end at the transmission if that is easier.
Old Apr 28, 2026 | 03:42 PM
stingr69's Avatar
stingr69
Buy some speedometer cable lube and pull the cable out of the sheath. Lube the cable well and the bounce should go away.
To C3 Needle Bounce
