81 ujoint bolt stripped
Old Jun 6, 2026 | 01:04 PM
Shaba's Avatar
Shaba
Default 81 ujoint bolt stripped
I'm replacing the 4 ujoints on the half shafts and 2 of the 12 point bolts stripped. I was able to remove the drive shaft since it was one bolt on the wheel side and one on the diff side. Tried a bolt extractor but it's for a 6 point and didn't work. Couldn't get a good bite. Anyone have any solid recommendations? Pound on a smaller socket? Doing on my back so not a ton of room to bang away. Thanks in advance.
Old Jun 6, 2026 | 05:38 PM
Bikespace's Avatar
Bikespace
When I did that job, I cut all the U-Joint straps. Then it was a lot easier to get a socket hammered onto the old bolts. I bought new straps and bolts from Spicer/Dana.
Old Yesterday | 02:47 PM
Rebelyell's Avatar
Rebelyell
Ya might weld a sacrificial socket onto em as well.
x2 on buying new spicer straps & bolts.
Old Yesterday | 04:36 PM
Shaba's Avatar
Shaba
Thanks for the advice. I got them out. I managed to wiggle the ujoints out of the dust caps and out of the yoke and remove the half shaft. That gave me more room to bang on a bolt remover which did the job. I was lucky as there was only one stripped bolt on each end of the shaft. Replacing all 4 ujoints on your back is a pita job though. Thanks again.
To 81 ujoint bolt stripped
