Oil Pressure Gauge Replacement C3
Need a little help before I start removing stuff to get to the oil pressure guage on my 70 C3. Started my Vette today and while in the driveway the oil pressure guage dropped to 0, turned off the motor and put a new guage on the pipe where the old guage was, started car, oil pressure 45PSI, placed a T in the oil feed pipe, connected both guages, the new one reads 45 PSI the original still reads 0. I ran a small thin wire in the plastic tube going to the original guage in the dash, this did not help, still reads 0. I guess I need to replace the original guage with a new one from one of the Corvette houses? Is there an easy way to get to and remove the guage? Does the center counsil have to be removed? Any help would be greatly appreciated. Yes, I could mount the new guage under the dash but this is a Corvette and I would never do that, I want to fix it correctly.
Bob in Boca
Bob in Boca
Center gauge console must be removed to replace the stock oil pressure gauge. May only need new oil pressure tubing rather than gauge, but still need to remove the center console.
I just replaced all gauges in my 71. Had to remove a 2nd, time to correct a bad wire on the fuel gauge.
My advice is this. The hardest part is getting to the 2 nuts that protrude down from the center console thru holes in the shifter console. They require a 3/8 wrench , a long one helps. You get to those by removing the radio access panels on the sides of the center console. You just have to keep turning a little at a time.
Since you have to seperate the gauge housing to get a gauge installed, I recomend removing it completly from the car to a work bench.
If lens is bad , now is the time to replace as well as the light bulbs
David
David
