Checking Muncie M20 condition. Have a question.
Old Jan 25, 2005 | 06:08 PM
ImBatman's Avatar
ImBatman
Default Checking Muncie M20 condition. Have a question.
Just got my M20 and was looking over the enternals to find out what I have to work with. Everything looks good. No broken teeth or other obvious failures. the syncros look a little worn but again none were broken. I plan on doing a rebuild kit on the trannie.
My question is how much play is any should be in the input shaft?
Output shaft?
Old Jan 26, 2005 | 08:02 AM
ImBatman's Avatar
ImBatman
Ttt
Old Jan 26, 2005 | 08:58 AM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Blackrat,
Mine felt loose. ie slop from side to side. I had mine rebuilt by Van Steel and when I got it back I did the same test. Now its nice and tight. You can get kits to do the work yourself but I didn't want to go in there. If it feels loos ie sloppy it proably has worn bushings/bearings.
The muncie is still what I would consider noisey ie gear noise but they all are.
Before you spend money on that box make sure you don't plan to put in a 5/6 speed in the near future. I would have put in a tremec if I had of thought about it. Now I have rebuilt mine I am not going to spend the extra money again.
Old Jan 26, 2005 | 09:34 AM
ImBatman's Avatar
ImBatman
Thanks for the info stingry. I considered the 5\6 speed but I just cannot justify the cost for a weekend car that may get 2-3k miles a year put on it if that. I picked up the muncie for less than 4hundred an figured I would learn how to rebuild it. Iknow the OD's are nice but I would rather spend the money somewhere else.
Thanks again!
Old Jan 26, 2005 | 11:49 AM
GTR1999's Avatar
GTR1999
You'll have some play in the input shaft. It is not part of the main shaft. They are not too hard to rebuild and the kits that Paul C sell are very good. I did the same thing you are planning, rebuilt my Muncie and ST-10 rather then drop $3,500 into a 5 speed kit for a weekend car.
Gary
Old Jan 26, 2005 | 01:32 PM
ImBatman's Avatar
ImBatman
Originally Posted by gtr1999
Paul C
Thanks for the info Gary. Who is Paul C?
Old Jan 26, 2005 | 02:38 PM
GTR1999's Avatar
GTR1999
www.5speeds.com = Paul
Old Jan 27, 2005 | 07:53 AM
ImBatman's Avatar
ImBatman
Thanks Gary. I actually realized how stupid my question was when I went out to that site and sent Paul an email asking which kit I needed. After seeing his last name it clicked as far as why you abbreviated it.
Wade
To Checking Muncie M20 condition. Have a question.
