77 Radiator support seals - Help
Old Jan 25, 2005 | 07:25 PM
colorado1967's Avatar
colorado1967
Default 77 Radiator support seals - Help
Need help identifying where radiator seals go on 1977 L48 w/air. Looking for both hood to support and radiator to shroud. Would greatly appreciate someone posting pictures or emailing pictures showing. My car did not have them and need directions for installation.
Thanks!
Old Jan 25, 2005 | 07:32 PM
hunt4cleanair's Avatar
hunt4cleanair
Thanks!
Dr Rebuild has illustrations that will beat the pants off of any photos that hardly do justice. He also has complete kits that probably include those instructions. BTW, your wise to get those in place...helps to keep it cool.
Old Jan 25, 2005 | 09:45 PM
Glassbowtie77's Avatar
Glassbowtie77
Try this link, this should do it.
http://www.zip-products.com/Corvette...BAFC18FF18312A
Old Jan 25, 2005 | 11:21 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Thanks!
this is from my 77 L48 orig w/air...you can orient the photos by the strut rod that goes from the bottom to the area in between the headlights...
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Jan 25, 2005 | 11:41 PM
colorado1967
Thanks to all, I was way off.
I thought they went between the shroud and radiator, not the support and radiator. To bad I have already installed the support and radiator! Can probably just remove the top two supports and tilt forward to install?
Old Jan 25, 2005 | 11:57 PM
bobs77vet's Avatar
bobs77vet
is the ac stuff hooked up yet? if not probalby easiset way is to just take off ac coils (2 small bolts) and reach in and slip it in place....
To 77 Radiator support seals - Help
