Fu#$%% $ Transmission Dipstick...
Old Jan 26, 2005 | 11:43 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Fu#$%% $ Transmission Dipstick...
Installed the transmission dipstick this evening.. A task that seems to be a 10 - 20 minute task took me almost 3 hours... :
I converted from manual to automatic transmission and there was never a dipstick in that location.. There was a stud and bracket that were riveted to the body, holding a thick ground wire... The bracket wasn't accessible from below the car.. I tried without success to slide the dipstick from the bottom to the top, bypassing that stud.. without success.. I finally determined that it was impossible to get the dipstick in with that stud in place.. I ended up drilling out the rivets (from inside the car) and cutting off the ground wire with my dremel cut off tool... Finally I was able to slide the dipstick in.. However, getting it into the correct location was another difficult task.. but after playing around with it, I finally got it in...
I was actually planning on re-doing the fuel pressure regulator setup, but the tranny dipstick had other plans with my time
Old Jan 27, 2005 | 12:15 AM
74FLCONV's Avatar
74FLCONV
I hear you...nothing (almost) ever goes as it should.
Changing my starter has turned into a major project. Trying to re-solder a fusible link...upside down...with hot solder dripping on my face. A 30 min. job has gone on for two days now.
D. Ocean
Miami, FLA
Old Jan 27, 2005 | 12:17 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
3 hours for a dipstick....what have you been stealing my install secrets...
Old Jan 27, 2005 | 12:20 AM
Schmucker's Avatar
Schmucker
I'd think you'd just go and buy a Lokar flexible replacement. I have a BOP dipstick on my 200-4R, doesn't fit the Chevy engine at all and doesn't clear the hood. The chopsaw fixed that problem.
Old Jan 27, 2005 | 02:13 AM
C371's Avatar
C371
I hear you! I had my new 200-4R in and out 5 times fitting the dip stick and cooling lines. And my elbow will never be the same from hitting the jack stand so many times!
Old Jan 27, 2005 | 03:52 AM
mrvette's Avatar
mrvette
I rmember when I fixed the 700 tranny for the 3/4 clutch pack some 2-3 years ago....I put the tranny in and forgot the damn dip s hit tube....fought it for 30 minits, and hell with it, cut the damn thing into two sections, and slipped a rubber hose over it to join them, and so it's been that way for a long time now...
it works, case closed....
GENE
Old Jan 27, 2005 | 05:02 AM
UKPaul's Avatar
UKPaul
Don't I just know this one! 3 hours? You were lucky. How about 2 days when I did my 200-4r? I put a post up on hints & tips for installing a 200-4r which should still be in the archives. Highly recommend anybody installing one should find that post as those ****ing dipsticks can drive you insane.
Old Jan 27, 2005 | 05:27 AM
guppie's Avatar
guppie
St. Jude Donor '08
According to Hoyle does not apply to anything, car repair, plumbing, electical, etc.
Murphy's law usually works better.
I usually guess about how long it should take and then multiply by 1000
Old Jan 27, 2005 | 06:54 AM
UKPaul's Avatar
UKPaul
So-ooooo, we have an pessimist on the forum It's more realistic to take the estimated time in hours & convert directly to weeks!
(edited due to incompetence!).
Old Jan 27, 2005 | 07:44 AM
isosceles's Avatar
isosceles
I know the feeling. You think you have the project licked when the motor mounts match up to the frame.
It's the little stuff that drives ya nuts.
When it comes time to replace my converter, I'm seriously thinking of yanking the motor out instead of the tranny
I KNOW how do that job, and all the little conversion stuff has been taken care of.
GrandSportC3
If I would've known what a pain this would be, I would've gone with the flexible Lokar piece...
Now I'll still have to attach the transmission cooler lines
Will try to do that tonight... Have to get the right fittings first..
Old Jan 27, 2005 | 07:51 AM
isosceles's Avatar
isosceles
now I don't feel bad having paid Vansteel to install my tranny and wire the converter lockup Sounds like it was money well-spent.
Old Jan 27, 2005 | 08:01 AM
GrandSportC3
I'm glad that I have a none-lockup race converter..so I don't have to wire the converter...
Old Jan 27, 2005 | 08:57 AM
comp's Avatar
comp
GENE
Old Jan 27, 2005 | 09:25 AM
mvftw's Avatar
mvftw
Just curious, why did you de-value your car? Are you making a track car?
Old Jan 27, 2005 | 09:40 AM
bobs77vet's Avatar
bobs77vet
D. Ocean
Miami, FLA
i used a weather proof crimp connection that had a sealing glue in it.. why not unplug and take the harness out and do it on the bench...on my 77 it consisted of 4 wires....and unplugged from a connection on the firewall....
Old Jan 27, 2005 | 11:40 AM
GrandSportC3
mvftw, the car will probably see more track time than street time, even though I'm going to still drive it around town.. Value was never a consideration. I already got approx. 80k into the car and I wouldn't even get 20k for it if I'd sell it...
To Fu#$%% $ Transmission Dipstick...
Old Jan 27, 2005 | 11:50 AM
LOTAHP's Avatar
LOTAHP
"O", jobs tend to take 3x longer when you are in a rush. OH yea, when I switched from an M-20 to a TH350, the Lokar dipstick took about 20 minutes to install.
Old Jan 27, 2005 | 11:53 AM
GrandSportC3
I wish I would've known before what a pita the install would be.. I'd have used the lokar dipstick for sure!!
Old Jan 27, 2005 | 12:19 PM
LOTAHP's Avatar
LOTAHP
But the lokar is $60 compared to the $15 POS you spent 3 hours trying to install.
