What is this cable for?
Old Jan 27, 2005 | 10:20 PM
Vette Gator's Avatar
Vette Gator
Default What is this cable for?
While changing the oil on my 76 TT last night, I noticed a cable attached to the transmission shift lever near the point where it enters the case. This cable is inside a steel wire-wound housing (about 1/4 inch in diameter) that goes up near the fire wall and ends close to the steering shaft. The cable has an attaching ring at this top end, but it wasn't hooked to anything. As a new Vette owner, please don't laugh if the function of this cable is obvious. I just figured that GM probably didn't install cables to nowhere on my car, and that unlike Bubba, I might prefer that it be attached where it's supposed to be!
Old Jan 27, 2005 | 10:23 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i don't have this on my 77 but some earlier years had a shift lock out cable that was actuated with the steering wheel lock that prevented the car from being shifted without the key in the ignition...
Old Jan 27, 2005 | 10:24 PM
matchframe's Avatar
matchframe
Sounds to me like it could be the speedometer cable. Does the speedometer work in your Vette?
www.bigdogvettes.com
Old Jan 27, 2005 | 10:29 PM
bobs77vet's Avatar
bobs77vet
[QUOTE=matchframe]Sounds to me like it could be the speedometer cable. Does the speedometer work in your Vette?
....and taking matchframes idea one step further if you car came with cruised control, it could be the first half of the speedo cable the one that went to the transducer....and then a different cable went from the transducer to the speedo cable. the transducer would be mounted under the brake master cylinder.
Old Jan 27, 2005 | 11:37 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I would also bet it's the theft-deterrent cable that locks the shifter. It should terminate at a small lever on the steering column.
Old Jan 28, 2005 | 09:18 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
yep, it is a steering wheel lock, and shifter lock, when you left the car, you would shift into reverse, take the key out, and it would lock the steering wheel, and make so you could not shift out of reverse. - that is if it still works. Bonehead that had mine previously snipped the cable
Old Jan 28, 2005 | 10:26 AM
Edzred72's Avatar
Edzred72
Trans interlock cable.
Eddie
Old Jan 28, 2005 | 10:29 AM
Edzred72's Avatar
Edzred72
Trans interlock cable. Same function, but different hook up for auto trans or manual.
Eddie
Old Jan 28, 2005 | 11:07 AM
djcwardog's Avatar
djcwardog
Check your assembly manual and see if you can attach the cable properly at the top...
To What is this cable for?
