Heat Rise Question
Old Jan 28, 2005 | 11:45 AM
Gage's Avatar
Gage
Default Heat Rise Question
When the valve is closed (cold engine) does it completely block off the exhaust from pass side of the engine, forcing it back up through the crossover in the manifold? Is that how it works?I think mine might be stuck part ,all the way.
Old Jan 28, 2005 | 11:52 AM
djcwardog's Avatar
djcwardog
Goal: what it does is cause a restriction in the exhaust gas flow on the right side when the engine is cold - and the valve is closed. Because the gas will flow in direction of least resistance, it flows through the heat riser passages at a higher rate than when the engine warms up and the heat riser gets heated up and rotates the valve open.
Reality: These valves get sticky quite often and tend to stay in one position or the other if left alone. Good luck is if they stay open - at least you get proper exhaust flow. Bad side on that is you don't get the help in warming up the engine. On mine - wired the valve in the open position and forgot about it! A better solution would be to buy a spacer - had one ordered once but it was out of stock, indefinitely. I just cancelled that part of the order...
Old Jan 28, 2005 | 11:58 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Yes, that's how it works....you will get some exhaust through the pass side with it closed but not much.
With time they do rust and or corrode in place. A lot of folks either wire them open or remove it completly especially if only driving in warm temps.
Old Jan 28, 2005 | 12:18 PM
Gage's Avatar
Gage
ahh, so that may explain why my vapor lock issue is intermittent. Sometimes heat riser valve is sticking closed, sometimes is is opening. I'm going to wire that thing open.
Old Jan 28, 2005 | 12:35 PM
Paul L's Avatar
Paul L
Mine is welded open.
To Heat Rise Question
