73 Stereo install advice
Old Jan 28, 2005 | 07:20 PM
zymosan's Avatar
zymosan
Default 73 Stereo install advice
Im putting a stereo system in my 73 this weekend, anyone have any advice/tips that i should know about?
...pics of install will be provided once complete :-)
Old Jan 28, 2005 | 08:42 PM
zymosan's Avatar
zymosan
So here is all the stuff thats going in this weekend, i was wondering though, am i going to need a new alternator, like a 100amp one or something?
Old Jan 28, 2005 | 09:36 PM
carl a's Avatar
carl a
watch you dont pinch the vaccume lines in there! the last owner of my 73 did and none of the acuators worked when i bought the car,, found the radio pinching the source vaccume line!!!
Old Jan 29, 2005 | 12:41 AM
Todd68's Avatar
Todd68
When I put a new system in my car (68) last summer I found the clearance between the pre-amp outputs at back of head unit and heater ducting was really tight. I found some cables (Soche?) with right angle connectors at one end which made a huge difference. Not sure if it's the same for your year or not, but maybe this tip helps.
Old Jan 29, 2005 | 03:52 AM
djcwardog's Avatar
djcwardog
Nice to see that you got a new faceplate with the DIN cutout. Be very careful installing it - the top portion will break very easily. Then you'll be like the rest of us who fit two pieces in carefully very time we have to pull the center out... There is a recent post here from a lady who had her interior redone - very nice! Anyway, she shows a nice CD changer case and rear speaker bar. Find that thread and see what you think...
Old Jan 29, 2005 | 07:41 PM
1FUNVET's Avatar
1FUNVET
I believe this is the thread you speak of.
http://forums.corvetteforum.com/showthread.php?t=999776
Old Jan 29, 2005 | 08:39 PM
A C's Avatar
A C
Cruise-In II Veteran
It looks like you have the Vette Specialties DIN bezel, so you made a good move right there. It gives you an inch or so more room behind the radio and looks factory stock once you get everything all mounted up. Be prepared for some frustration routing RCA cables and speaker wire (if you are using a healthy guage). I rivited some rubber coated looms to my trans tunnel to route the wires. It keeps them protected and is totally invisible with the carpet in place. Also, mounting the speakers properly can be a pain...just be patient and don't compromise. If you compromise with crappy mounting methods or by downgrading to smaller speakers, you'll be sorry and be back changing things again. Just be patient, don't force things, work around obstacles....I am sure you'll be happy. Looks like you have some pretty nice equipment there, it's gotta sound better than stock!
Old Jan 29, 2005 | 11:17 PM
zymosan's Avatar
zymosan
Well we got the to dash speakers installed, and we built the box for the sub... most of today was spent getting tools and supplies.
Tomorrow is the all the rest, you can check out the pics below...
[html]http://homepage.mac.com/zymosan/PhotoAlbum10.html[/html]
Old Jan 30, 2005 | 02:06 AM
codestar7's Avatar
codestar7
Default Only the Best
zymosan........You ar ethe Man only the best!..a 73 C3 and an Apple Computer! Right on Brother!
Old Jan 30, 2005 | 08:07 AM
1FUNVET's Avatar
1FUNVET
I love the pick of you upside down in the drivers seat!! That really made me laugh!!!
Old Jan 31, 2005 | 11:52 AM
zymosan's Avatar
zymosan
Well the stereo is installed and kind of working, but we weren't able to find a suitable place to put the ground, so i figured i would just attach it to the battery ground... unless someone else has a better idea.
Also the car is still in pieces, my friend who came to help my had to leave last night before we could put it all back together, but i should be able to finish the rest by my self. It will also give me a little more time to make sure that everything is seated properly.
I'll post more progress pictures tonight for anyone who is interested.
Eric
Old Feb 2, 2005 | 02:48 AM
zymosan's Avatar
zymosan
Well i finally got everything installed... and it sounds awesome!
Alas this indevor was not with out casualties... so far i've lost a couple of screws, the speedometer is acting very weird and won't go past 40mph, and the fuel gage is reading at full even though i know its not.
Pictures are posted here:
and any advice on the speedometer and fuel gage is much appriciated!
Eric
To 73 Stereo install advice
