Any benefits in Double Offset Trailing Arms
" Double offsets are the exact same as standard offsets except for the spring bolt hole. The spring bolt hole is pushed in 1"(toward the differential) so you must use a shortened spring. "
Some of the guys that are running the double offsets are notching their frames at the kick ups to get the extra room for even wider tires. Others just run the to be on the safe side when they run 10" rims. By having the spring bolt hole moved in and a shortened spring they don't have to worry about anything. Regualr offsets would be fine but some just have their superstitions.
It really depends what your trying to run for wheel offsets.
regular offsets are pretty good also.
Some of the guys that are running the double offsets are notching their frames at the kick ups to get the extra room for even wider tires. Others just run the to be on the safe side when they run 10" rims. By having the spring bolt hole moved in and a shortened spring they don't have to worry about anything. Regualr offsets would be fine but some just have their superstitions.Also ,since there is not a sway bar for the offset or double offset , does the shorter spring help with handling?
I bought a "Peformance Plus" suspension kit. This included a very hefty front anti roll bar, a rear anti roll, 500 pounds per inch front springs and a 360 pounds per inch rear composite spring, Bilstein shocks, etc.
I think it can be said that the rear anti-roll bars will only fit cars with pretty much stock tire widths. I have 255/R50-17 tires. The rear anti roll bar slightly rubs the tires. I've called up a few people, but so far the advice is just to run without rear anti-roll bars.
The 255/R50-17 tires will "just about" fit the stock suspension. The trailing arm parking brake bracket was about 1/8 inch away from the tire sidewall. The rear spring was perhaps 1/2" from the tire sidewall. I bought some new parking brake brackets from Volunteer Corvette to have them welded on top of my stock trailing arms. Then I decided this was too much work, so I just bought offset trailing arms from VBP and a composite spring from VBP (the spring shortened 1/2 inch on each side). Now....
When I attached the anti-roll bar, the sides slightly rub the rear tires.
I've talked to Vette Brake Products and also Guldstrand about this. They both have said it won't be a problem to run without the rear anti-roll bar. I guess if I had a torch, I could heat the rear anti-roll bars just a little bit to get them to clear the rear tires.
Also , I was under the impression that have a dual mount spring will eliminate the need for a rear sway bar?
One last question, If you eliminated the sway bar could you go wider and what would you run into (bracket, spring or frame)
Thanks for the input
I have 17X8 wheels with 4 1/2 backspacing. (Wheel Vintiques Billet Rallye). I have 255R50 X17 tires.
Yes, with the offset trailing arms and now that I don't have to fuss with the anti-roll bar I could go with bigger rear wheels. I don't know how much bigger...I'd have to go out and have a look. This is for the rear wheels. The 255R50X17's on the 4 1/2 backspacing are a little bit too big for the front wheels.. on a full left or right turn they just hit the body/frame just a little bit before I come to a maximum turn.
Also, my car car is a 1968. For example the 1970's have a bit of a wheel flare and they may have a little bit more room.
I have the 360# rear composite spring. My car is sitting about 2 inches too high. I curently have 8 inch trailing arm to spring bolts. VBP is sending me 10 inch bolts. This should drop my rear end height and also make the rear half-shafts parallel to the ground. Currently the differential output shafts (yokes) are about two inches higher that the spindle half-axle flanges. The bolts should be sized so that the half-shafts are parallel to the ground. A ten inch bolt should do it for me.
I built my own offset trailing arm and when I ran a buggy spring i also moved the spring bolt in 1 inch of each side and ran a shorter spring.
Will you get any improvments by going to shorter (inch on each side) fiberglass buggy spring?
That is probaly what I will have to do.
