Rear Main Seal - I hate it, need help
Old Jan 30, 2005 | 04:03 PM
diablo kid's Avatar
diablo kid
I had the same problem, only mine was the new felpro gasket leaking. The mechanic took the pan off again, and used some rtv at the rear where it was leaking, it still leaked a little bit. I put in a new PVC valve and it stopped leaking. Now did it just decide to quit leaking or was the valve not relieving the pressure as it should?
Old Jan 30, 2005 | 04:04 PM
diablo kid's Avatar
diablo kid
I had the same problem, only mine was the new felpro gasket leaking. The mechanic took the pan off again, and used some rtv at the rear where it was leaking, it still leaked a little bit. I put in a new PCV valve and it stopped leaking. Now did it just decide to quit leaking or was the valve not relieving the pressure as it should?
Old Jan 30, 2005 | 06:38 PM
72LS1Vette's Avatar
72LS1Vette
Originally Posted by jacobsed
Because I've never installed a rope seal? I'm 29 btw.
To some of us that qualifies as a youngster. My oldest son is almost 23.
Rick B.
Old Jan 30, 2005 | 07:34 PM
Poptops's Avatar
Poptops
Looks like it is not the rear main...thank goodness! Valve cover was leaking..oil ran down the block then along the bellhousing and dropped off the center line.
This is exactly what I just finished repairing on my '82. I had replaced the rear seal about 10 years ago along with the valve cover gaskets ... glad it was the VCs and not the rear main that gave it up "so soon".
Old Jan 30, 2005 | 07:42 PM
bracketshark's Avatar
bracketshark
If you have to change the seal again try using a Mr. Gasket single lip seal I have had good success with these compared to the felpros. You can get these from Jegs or Summit, any speed shop should be able to help.
