Well, you have high performance dampers and then you got stock dampers. Performance dampers can generally take higher rpm's before they fly apart. They last longer to. The timing marks shouldn't move like they sometimes do on stock ones. Did I mention they cost more?
I am running a Fluid Damper on my SB. It is degreed all the way around so timing is a breeze. The aftermarket dampers are better for any motor turning high rpms. The stock ones are fine for a driver and an occasional blast.
Be aware that 427's had 7" and 8" dampers originally. The hi-perf motors with solid lifters used 8" and the hydraulic lifter motors had 7".
If you have a small 7" diameter damper currently and want to go to 8", you'll either have to cut off your timing tab on your timing gear cover or go with an aftermarket cover and timing tab.
I got a 7" ATI superdamper for my 427 so I wouldn't have to mess with changing the cover and to retain the stock appearance.
For my 496 stroker motor, I'm using an 8" fluidampr.
In general for a given damper design, the larger diameter balancers are more effective at dampening harmonics than a smaller diameter damper but they have more rotating inertia.
Also be aware that 427's are internally balanced so a 454 8" damper won't work.
