Breaking Loose Seized Bolts
Old Jan 31, 2005 | 04:27 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Originally Posted by Larry B.
I have never seen any rear calipers with two cross over passage.. That's why there are two bleeders on the rear but only one on the front.
My rear calipers have 3 bleeders and the front 2, for atotal of 8.
Old Jan 31, 2005 | 07:28 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Originally Posted by jdmick
That PB Blaster is some nasty smelling stuff . I can feel my lungs turning carcinogenic when I use it.
It's similar to medicine - if it is not nasty it won't help !!!
Kroil and PB are both very good, after I spray a bolt I wrap one or two paper towels around the sprayed area and spray some more PB on/under the paper towel... trying to keep a moist environment.... can't say if it's necessary but it won't hurt....
Old Jan 31, 2005 | 08:10 AM
Edzred72's Avatar
Edzred72
You gotta order Kroil from Kano laboratories.. worth the effort.. Buy a gallon or spray cans. Best stuff I have ever used.
Eastwood also carries it. I found Kano Kroil worked faster than PB Blaster. I did a test on my trailing arm bushings last month. Soaked one with PB..the other with Kroil at least 4 times each day. Kroil worked in two days....Pb took three.
Eddie
Old Jan 31, 2005 | 08:11 AM
Edzred72's Avatar
Edzred72
Eddie
Old Jan 31, 2005 | 08:14 AM
isosceles's Avatar
isosceles
Originally Posted by redc3
PB blaster is real cool stuff!
Awesome stuff! Bolts are scared of it and just fall out!
