Problem with TH200Transmission cooling ports.
Old Jan 30, 2005 | 03:04 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Problem with TH200Transmission cooling ports.
They are 1/4 inch NPT ports but the 1/4 fittings just won't screw on...
Looked at the threads, but they lookd fine...
Any ideas what the reason could be??
Old Jan 30, 2005 | 04:26 AM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
hrrrrrrrrrmmmmm get a 1/4 tap and re tap it........but im a bubba.
Old Jan 30, 2005 | 08:29 AM
79VetteMike's Avatar
79VetteMike
Hey Oliver, with it being as tight against the tunnel as it is, I would have to guess you aren't able to get the fittings on there straight. Have you tried starting the threads by holding the fittings through the hole you made in the floor?
Old Jan 30, 2005 | 08:39 AM
redwingvette's Avatar
redwingvette
What are you trying to screw into them? They are a straigh thread designed for a flare fitting (such as a brake line), not a pipe thread which is tappered.
Old Jan 30, 2005 | 09:41 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I agree, not NPT...
Old Jan 30, 2005 | 10:58 AM
GrandSportC3
That's exactly what I tried.. I have direct access to the ports through the hole and still can't get it on..
Old Jan 30, 2005 | 10:59 AM
GrandSportC3
I'm heading to Advance Auto to get metal lines with the original type fitting..
Old Jan 30, 2005 | 11:52 AM
GrandSportC3
WOOO HOOOO - the brake line fittings work.. I cut off the pipe so that I can attach the braided rubber hose...
Old Jan 30, 2005 | 11:54 AM
Twin_Turbo's Avatar
Twin_Turbo
Have you tried BSP adapters????
Old Jan 30, 2005 | 12:01 PM
GrandSportC3
nope.. Don't even know what those are.. Anyway - I got it working with the brake lines and fittings..
Old Jan 30, 2005 | 12:15 PM
Twin_Turbo's Avatar
Twin_Turbo
bsp = british standard pipe, same sizes as NPT but without the taper (BSPT does have a taper)
Old Jan 30, 2005 | 12:19 PM
GrandSportC3
Thanks for the info!
To Problem with TH200Transmission cooling ports.
