Energy Suspension
Old Jan 30, 2005 | 12:25 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Energy Suspension
Has anyone used Energy Suspension? If so are they good? Thanks
Old Jan 30, 2005 | 12:40 PM
Corey_68's Avatar
Corey_68
I have the ES poly bushing on my '68, and really like it . Just use the grease they provide w/ the kit and it will not squeak.
Old Jan 30, 2005 | 12:41 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
i'm gettin ready to upgrade with VB&P... great people to deal with and never have heard a bad word about them!
Old Jan 30, 2005 | 12:57 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Me too.
Old Jan 30, 2005 | 01:18 PM
LFZ's Avatar
LFZ
Rebuilt my front end with ES poly kit, and i'm also running their motor mounts...great stuff, great price!
Old Jan 30, 2005 | 01:19 PM
djcwardog's Avatar
djcwardog
Default Rear Sway Bar Bushings...?
My only gripe: I bought a set of the small bushings (poly) intended to replace the stock rubber ones used with the rear sway bar. No way would those fit the stock bar... I have to find new rubber bushings sometime when I get home...another thing on the "to do" list.
Old Jan 30, 2005 | 01:21 PM
Edzred72's Avatar
Edzred72
Installed their poly strut rod, rear spring bushings & motor mounts when I had my 77. Very satisfied. Greased em up and no squeeks.
Eddie
Old Jan 30, 2005 | 06:08 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
i put a full set on my '81 years and years ago. i've had no problems with them. my only complaint with the set is there is absolutely no information in the kit describing which bushings are which. since some of the replacements don't look exactly like the ones they replace, it's a bit frustrating but you can figure it out.
Old Jan 30, 2005 | 06:15 PM
nitrocharger's Avatar
nitrocharger
I have poly everywhere except the trans mount, its good stuff. Just put extra grease in there.
Old Jan 30, 2005 | 07:24 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
They are really hard to get on the sway bars. I would measure the bar and bushing diameter again to make sure they are the same. You will have to take screwdriver to pry them open and slide it on the bar at the same time.
Old Jan 30, 2005 | 07:34 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
My transmission mount is from "Engery Suspension"
Old Jan 30, 2005 | 07:53 PM
redc3's Avatar
redc3
youll really like the stiffer feel. and go to local store and buy an extra set for the front shocks ( a-zone has them ), and put them on your steering ram. you wont get that one in your kit.
Old Jan 31, 2005 | 07:05 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Been on my vette for over 6 years now with no issues
To Energy Suspension
