header bolts
Old Jan 30, 2005 | 08:25 PM
greyghost79's Avatar
greyghost79
Default header bolts
anybody got a trick to get header bolts on and off "easy". bolt heads are so close to the headers that you can only turn them about an eighth of a turn with an open end wrench before you have to reset the wrench. no room for a socket. bolts at firewall end are impossible.
anybody using internal hex head bolts? that seems like the way to go to me. any down side to them?
Old Jan 30, 2005 | 08:47 PM
jdmick's Avatar
jdmick
I just got some Stage 8 locking header bolts I'll be trying out this week. I can let you know how that goes.
Old Jan 30, 2005 | 08:50 PM
Glassbowtie77's Avatar
Glassbowtie77
That's the way to go.
Old Jan 30, 2005 | 09:05 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I don't have a problem with getting a wrench on mine. I use a 1/4 drive ratchet and a 3 inch extension with a 3/8 socket. Works good to tighten them on my headers. The one thing I do have a problem with is they back off all the time and need to be retightend after every long cruise. I guess I should invest in a set of those Stage 8 locking fasteners too.
Old Jan 30, 2005 | 09:14 PM
jake1's Avatar
jake1
Finished scaring up my knockles a few months back doing the same, just be sure to keep checking thier tightness once in a while, if you don't use the locking type.
vette rod's Avatar
vette rod
Go with a set of stainless allens (socket head type or button head) and a little never seize on the threads.
Old Jan 30, 2005 | 09:40 PM
Red 69's Avatar
Red 69
Stage 8 worked for me after others failed. Fit them right the first time and never need to tighten again. After the bolts are torqued, you fit the lock against the header tube. Some grinding may be necessary for a good fit on the locks. No more blown gaskets from loose bolts.
Old Jan 30, 2005 | 10:24 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
buy a combination wrench and take the box end side to a grinder to thin out the metal this will then slip over the hex head and you will get a more full turn..........
Old Jan 30, 2005 | 10:38 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
To header bolts
