Your typical header flange arrangement has these attaching to the headers then thru 2 and 1/2 pipe thru the frame cutouts and then another set of flanges like above on the other side of the cutouts to allow you to pull the exhaust for work to the rear end/ spring etc. Now either way I'm stuck with a length of pipe with flanges on either side that won't let me remove that pipe save for me welding them off.
Has anyone came up with a split flange design that allows you to remove the entire length of pipe (one piece from the header collector all the way to the muffler) thru the exhaust cutouts off the car.
Using a JBA seal (small enough to fit thru the cutouts) and with the flange itself, make one out of hardened steel or T04 that is minumum 1" thick. Cut exactly in half but threaded inside on both sides using 2 allen bolts (a picture would be nice here) so it could be removed off the pipe and the pipe pushed thru the cutouts.
Ideas?
Edit update
currently the PO put non-stainless 2.5" solid 1-piece from headers all the way back to mufflers, tranny, rear spring, rear end work is not an option due to Bubba's work.
That's a tough question. I'd love to hear the solution. Its a difficult job just getting the 2.5" pipe and the flared out ends like you have pictured above through the cutouts. You can't get stock style flanges through there, that's for sure. The only thing i can think of is a clamp setup where you swedge out the ends (Make the pipe 2.5" ID), put it around a standard piece of pipe and run a regular U shaped exhaust clamp. Something like this...
Another thought. If you've ever seen/heard of the header hush, maybee someone can help me with a diagram or picture of one. You could flare out both ends and and make a header hush connection with a standard collector gasket in between.
take the pipes to a muffler shop they will expand the pipe with the flanges on the pipe...then use the flat flange gasket to seal the exhaust..you will need two flanges per pipe, ditto with the gaskets...
Clamps suck IMO, they crush the pipes and scrape the streets (or you have to turn them upside down)
A better idea would be to duplicate the slip on part of the drawing but weld tabs on both sides of the pipe, these tabs would then sit against each other and a bolt can be run through them, the tabs don't have to be big and2 on each pipe will do the trick.
Clamps suck, I agree, but they serve a dual purpose: The clamping force crushes the pipe, therefore providing a positive seal and clamping the two pipes together.
A proper setup slip fit will seal off the pipe also, no need to go crush the pipe. A little high temp sealant between the slip joint and it won't leak nor rot tight together (in cse of non stainless exhaust)
As for clamps sealing off the pipe, they also create leaks when tightened too tight, the pipe will crush on the top and bottom, and it will deform to an oval shape, resulting in leaks on the sides.
Yes, those are a good alternative, especially the upper ones, i use those for silicon hoses & rad. lower hose also. They will only work properly if you cut a couple of slits in the expanded section of pipe.
okay if I understand right using the picture in the 1st reply I can use the 1st clamp pictured. Would not the "swelled" 2.5" ID going to 2.5" OD create a ledge where there would be leaks?
If the exhaust removal is truely a issue, why not modify the cross member for removal. I've not done it but I can think of times in the past I should have made an attempt to make my pipes easier to remove.
This is the way I do it. Modify the crossmember to allow the pipes to run underneath, not through and at the same time move the exhuast outboard more to keep the heat away from the transmission.
This is a old picture and I no longer use this exhaust but it is a full 3 inches, runs under the crossmember and moves it out from the transmission.
I don't like clamping the pipes either. My mufflers are slid on and then only lightly clamped to prevent crushing the pipe.
I hate exhausting work, it's a PIA on any car, and a super duty PIA on any vette,.....
I take it down the street and have Ricky weld it up any way he likes...and it works.....
when I cut the system open from time to time, I choose a straight section to cut through, then wrap some galvanized flashing around it, with hose clamps, surprisingly quiet for trips to Ricky's for rewelding....sometimes I leave it on there for several months....
Gene, you are starting to sound like bubba, just as in the dipstick thread..cutting it in 1/2 and slipping over a rubber hose...next time you want to do stuff like that, step away from the car
