Tach on a 69
Old Jan 31, 2005 | 07:21 PM
carhound's Avatar
carhound
Default Tach on a 69
Does just the Corvette have the distributor tach drive, or did other G M cars have them.
Old Jan 31, 2005 | 07:35 PM
Z-man's Avatar
Z-man
Summit only shows them for "racecars" or Corvettes. There might be others...
Edit: Looks like Camaros had 'em too...
Old Jan 31, 2005 | 09:03 PM
kdf1986's Avatar
kdf1986
I was looking at some websites and found a photo of a
1956 Chrysler/Desoto mechanical tach drive distributor.
http://www.dacoglu.com/Tach.htm
I also found some other cars that used a mechanical tach drive such as the Porsche 914
Vehicle/Engine Specs:
Make: Porsche Model: 914
Engine Type: 2.0L Transmission: 5sp
Modifications: Bored 2mm, stroked 7mm, dual 44mm Webers, Moderate cam and opened heads.
Discussion Topics: distributors
Solution:
45 series has centrifical advance only. 47 series has centrifical and vacuum advance. 46 series is the same as 45 series but with a mechanical tachometer drive for use with cable driven tachometers. Use the 46 series only if you have a cable driven tach.
kdf
Old Jan 31, 2005 | 09:51 PM
Dick Whittington's Avatar
Dick Whittington
Solution:
kdf
I think that that distributor was used on some marine, industrial, or truck engines. Or all of the above
Old Jan 31, 2005 | 09:54 PM
Dick Whittington
The tach drive distributors for Camaros were an over the counter item. They were listed in the early Chevrolet Power manuals along with the Cross Ram intakes, Kustom headers, etc Part # was 1111267
To Tach on a 69
