Noisey Differential
Old Feb 1, 2005 | 08:25 PM
82moneypit's Avatar
82moneypit
2nd Gear
Default Noisey Differential
Friends 80 Corvette with all new differential is knocking during deceleration.At 60-70 MPH it sounds like muffled machine gun fire.At 30 mph and below it sounds like two hammer faces being struck together.
Noise is in differential,not u-joints,transmission,t-arm bearings or differential mount.Its gears or posi-unit but which?
Old Feb 1, 2005 | 09:04 PM
wombvette's Avatar
wombvette
Hard to say, but, if it is only under deceleraton I would look at the front snubber bushing. If it is loose or bad, that will allow the U-joint to hit the body or the frame. Another possibility is a very badly set up pinion or a loose pinion.
Old Feb 1, 2005 | 09:09 PM
GTR1999's Avatar
GTR1999
sounds like a loose pinion or bad pattern.
Gary
Old Feb 3, 2005 | 12:08 PM
bs82vette's Avatar
bs82vette
Sounds a lot like my problem.I can do one tight turn in reverse and then when i go forward it sounds like crunching gear teeth for the next mile and then it gets quiet again?Anyone got an answer?
Old Feb 3, 2005 | 12:20 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
anybody want to see pictures of what happens to a differential when a pinion gear shears off the shaft?
Old Feb 3, 2005 | 12:21 PM
GTR1999's Avatar
GTR1999
Sure!
Old Feb 3, 2005 | 12:22 PM
Twin_Turbo's Avatar
Twin_Turbo
Let me guess.... a big hole on the pass side in the case, right where the pinion bearing is. Happened to me too..don't have a pic. Show it
To Noisey Differential
