I was curious, how hard is it to make a automatic frame into a manual one? Just the clutch Z bar pivot is the only difference, right? Is it just welded on?
Also, a 68 and 69 frame: I have a 68, and am looking at a 69 frame. My understanding is that the only difference (that matters) is the front frame horn extentions? Is this correct?
Now, to modify, do I need to extend the front frame horns, or can I just use 69-72 bumper extentions/brackets? I would assume that this would work, considering that the bumpre is the same.
or you can buy the bolt-0n cross shaft hanger that they used in the 80-81's. I have an early weld on peice and a later bolt on peice. Haven't decised which way to go yet. Whether bolted or welded, the diminsions and heigth appear the same...
Cris
Visually, the 68 and 69 frame look alike in the front. I'm pretty sure all of the front bumper supports, extentions, and bumpers are interchangeable. I'd be surprised if there's any difference.
I think the only difference between the 68 and 69 frame is that the early 68 frames were lacking a reinforcing gusset where the wheel arch is welded to the to the forward part of the frame.
All of the C3 frame changes throughout the years are discussed, with photos, in a corvettefac.com. article. I tried to find it, but the corvettefac server is just really slow right now.
