Paging Grandsport
Old Feb 2, 2005 | 08:22 PM
redc3's Avatar
redc3
Default Paging Grandsport
sorry if i missed your reply. in another thread, i saw your burnout, and asked if you still had IRS under that thing. if not, what changes have been made? if you still have it, do you have any upgrades? thanks. jack
Old Feb 2, 2005 | 09:51 PM
redc3's Avatar
redc3
ttt
Old Feb 2, 2005 | 09:53 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
Last I knew, he did
Old Feb 2, 2005 | 10:14 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Why don't you PM him??
Old Feb 2, 2005 | 10:35 PM
shoptek's Avatar
shoptek
He still has IRS with an Eaton unit, but he is changing it out with the new motor/tranny to a Tom's unit IRS I believe.
I spoke to him tonight, and he is making progress.
Old Feb 3, 2005 | 03:36 PM
redc3's Avatar
redc3
thanks, his car is impressive and cant wait to see mine doing the same thing.
Old Feb 3, 2005 | 03:46 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I ran a stock IRS so far and already broke a few differentials.. Surprisingly the axles held up so far..
Right now I'm waiting for Tom's 12-bolt IRS setup... Which should be strong enough for 9's at the track... However, it's kinda pricey..
Old Feb 3, 2005 | 03:53 PM
GrandSportC3
Marc, I actually ran a Auburn and not a Eaton unit. The Eaton lasted less than 20 passes at the track and the Auburn lasted about 35 - 40 passes...
Old Feb 3, 2005 | 04:28 PM
comp's Avatar
comp
spool this time ?????
Old Feb 3, 2005 | 07:46 PM
GrandSportC3
Spools are only for dedicated race cars.. Mine will be frequently driven on the street and therefore a spool is a for me..
Old Feb 3, 2005 | 07:57 PM
comp's Avatar
comp
read here and have seen on the street and you May need it
Old Feb 3, 2005 | 09:02 PM
redc3's Avatar
redc3
thank man, ill be looking for your advice soon on how to change rear ends as i plan on giving mine he77
Old Feb 3, 2005 | 09:23 PM
comp's Avatar
comp
need to see the carbon-fiber goodies
Old Feb 3, 2005 | 10:20 PM
GrandSportC3
A spol will wear down the axle bearings if you drive more than a couple 100 miles on the street... The stress on the bearings is very high in turns, and on longer trips, that is very bad for the bearings and also axles...
Old Feb 3, 2005 | 10:21 PM
GrandSportC3
There's not really too much to it...
To Paging Grandsport
