Pushrod Length
Old Feb 3, 2005 | 06:37 AM
wogs73's Avatar
wogs73
Default Pushrod Length
Anyone know the correct length for the Jegs 197 head with a stock 350? Anyone use these heads and have any comments on them?
Old Feb 3, 2005 | 07:14 AM
Gordonm's Avatar
Gordonm
The only way to do this correctly is to get a pushrod checker. Every block and head has tolerances. What fits one engine might be to short or long for another. The checkers are cheap and easy to use. Get one then order what size you need. I had to go .100 longer with my AFR heads.
Old Feb 3, 2005 | 07:50 AM
Edzred72's Avatar
Edzred72
Originally Posted by Gordonm
The only way to do this correctly is to get a pushrod checker. .
You can also call tech support with your stats...and they can suggest required length. I used the checker and it was precise and easy to do.
Eddie
Old Feb 3, 2005 | 07:53 AM
djcwardog's Avatar
djcwardog
Have tech support send you their recommended rods - and a checker!
Old Feb 3, 2005 | 04:23 PM
wogs73's Avatar
wogs73
Since there are so many different checkers out there could you recommend any certain one? I probably will only use it once.
Thanks again
Old Feb 3, 2005 | 04:26 PM
comp's Avatar
comp
Thanks again
good question
To Pushrod Length
