How much additive?
Old Feb 3, 2005 | 12:43 PM
MAC74's Avatar
MAC74
Default How much additive?
I am just about to put my new rear diff in and I was wondering how much additive to put in with the gear lube?Also what type of gear lube should I use?
Old Feb 3, 2005 | 12:46 PM
pws69's Avatar
pws69
1 bottle of GM Posi Additive
I use Mobil1 and I really like it - but that can turn into a thread on it's own... and has many times!
Old Feb 3, 2005 | 12:51 PM
MAC74's Avatar
MAC74
Thanks.Im going to get this in tonight and maybe,just maybe I will be able to take a ride tonight.
Old Feb 3, 2005 | 01:57 PM
Maco Shark's Avatar
Maco Shark
I just changed mine in the 82 yesterday.
1 bottle of additive and 3 1/2 bottles of GM 80-90 wt.
You can add an extra bottle of addtive if you want to.
Get you a suction gun and go at it.
I put the additive in first and then the lube.
I make a few slow figure 8's to get everything lubed up good.
I am sure there is a bunch on here about exactly how to do it.
Thats just my .02
I also changed my rear end snubber bushing. that is a different story altogether.!
Old Feb 3, 2005 | 02:01 PM
Gordonm's Avatar
Gordonm
I use 2 bottles of the Gm additive and use the GM lube.
Old Feb 3, 2005 | 02:03 PM
comp's Avatar
comp
2 bottle's if it hasn't been changed for a long time
Old Feb 3, 2005 | 02:06 PM
MAC74's Avatar
MAC74
This is a rebuilt 3:55 that has 0 miles on it.I pulled the old one out last weekend and I hope to have the new one in tonight.
Old Feb 3, 2005 | 02:09 PM
i885744's Avatar
i885744
Is the "limited slip" additive that kragen sells any good? I drained mine (origional fluid after 30+ years) and put in 1 bottle of the limited slip additive and topped it off with fresh fluid. It still whines at 60mph. Goes away by 70mph. Think i should drain and refill with a couple genuine gm bottles?
Old Feb 3, 2005 | 02:18 PM
pws69's Avatar
pws69
POSI additive won't have any effect relative to the whine. WHen it gets old or isn't used, the POSI clutches are grabby and chatter/clang.
Replacing the fluid might help the whine. I found that the Mobil1 quiets gears down better than dino oil.
Old Feb 3, 2005 | 02:22 PM
comp's Avatar
comp
can't hurt, may be a waste of money but i would anyway
To How much additive?
