Manifold - Recoating for better appearance
Old Feb 3, 2005 | 10:56 PM
etech152's Avatar
etech152
Default Manifold - Recoating for better appearance
I know very little about engines and need suggestions. My Manifolds need some detailing. Anyone ever recoat your Manifolds while they are still on the car using the small brush and dressing. Can it be done that way? Or do I have to remove them.
Old Feb 3, 2005 | 10:57 PM
etech152's Avatar
etech152
I should add that I have a 69 Corvette with L46 350hp engine with factory A/C P/S P/B. You can see my engine in my avatar and my photo album. Manifolds look rusty compared to the rest of the engine. I could also use a little detailing here and there under the hood to make the car a little more show worthy. It is in paint shop right now and will be finished painting in less than 3 weeks.
Old Feb 3, 2005 | 11:22 PM
topless68's Avatar
topless68
assume your referring to your exhaust manifold?
Old Feb 3, 2005 | 11:26 PM
etech152's Avatar
etech152
Yes, that is correct!
Old Feb 4, 2005 | 12:07 AM
74Thrasher's Avatar
74Thrasher
Calyx manifold dressing. Got the idea from someone on here, can't remember who. Works great
Old Feb 4, 2005 | 12:14 AM
KENS78SILVERANNIV's Avatar
KENS78SILVERANNIV
Before you go through all the trouble. Put the car up on a lift and take a good, long look underneath with a bright light.
I found two long cracks in my manifolds when I started detailing my engine. Wound up replacing them along with new bolts, heat shields, etc.
If yours are the original iron manifolds... there's a good chance they could be warped, cracked, rusted etc. GM still makes the originals and when you paint them up with manifold paint... they look better than new!
Good Luck.
Tomorrow's lesson.... how to get those old bolts loosened up.
Old Feb 4, 2005 | 12:19 AM
dwe's Avatar
dwe
does a really nice job and leaves a finish that doesn't look like paint. You may have to redo once a year but it looks great. Put it on with a tooth brush, no need to remove manifolds or non flaky rust. See covettefaq.com for some ideas about using this stuff for other parts.
Old Feb 4, 2005 | 01:54 AM
etech152's Avatar
etech152
Thanks guys! I already have the dressing in a Jar with a brush. I got it from one of the major Corvette vendors. I just wanted to know if I could apply it on the exhaust manifolds without having to remove them. My manifolds are fine and work great, no cracks. Just would really make a hugh difference in appearance under the hood. Also the part which holds the brake fluid could use some cleaning up or paint too, the top part looks fine (as you can see in photos). These two parts are the biggest items I need to detail along with the firewalls (just lightly spraying them black should work) and of course touching up the heat mark on the red-orange intake. One more question, after applying the manifold dressing, do I crank the car up and let the manifold cure the dressing and thats all I do and it's finished?
Old Feb 4, 2005 | 04:48 AM
carl a's Avatar
carl a
i took mine off and had them sterling coated by air bourne coatings-al=lso did the radiator's fan,chambered pipes and a lot of other parts------
Old Feb 4, 2005 | 11:19 AM
rponfick's Avatar
rponfick
I've had excellent results with Eastwoods manifold spray coating.
Old Feb 4, 2005 | 11:55 AM
kcmk's Avatar
kcmk
I used Eastwood. Problem was, I first tried brush coating them while still on the engine. Over time, several small rust spots bled through. I ended having to remove them, having them media blasted, and then coated with Eastwood before re-installing.
Old Feb 4, 2005 | 12:23 PM
mvftw's Avatar
mvftw
I had my stock aluminum manifold powdercoated...plus it resists oil and gas...
Old Feb 4, 2005 | 02:00 PM
NHvette's Avatar
NHvette
Paul hasn't chimed in yet. He (and others) have successfully
used a graphite spray-on lube. When it dries, it leaves the graphite
as a coating.
The answer is YES - calyx with them on the engine is OK.
Also, brush-on heat paints like POR-20 work OK.
Old Feb 4, 2005 | 04:27 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
POR-15 manifold paint.
Old Feb 4, 2005 | 04:34 PM
page62's Avatar
page62
I had mine ceramic coated. Many street rodders do this. It starts out looking very silver, but dulls slightly to a nice finish. Practically indestructible!
Old Feb 4, 2005 | 08:50 PM
Emmett's Avatar
Emmett
Calyx works great but are about ready for a recoat
Old Feb 5, 2005 | 05:54 PM
etech152's Avatar
etech152
I have some of the Calyx I just ordered. Looks like it will be easy to apply to the exhaust manifolds right on the car.
I also have some "Performance Choice" #106-908 Manifold dressing by Mid America. It comes with a small brush. I don't know how well this stuff works.
To Manifold - Recoating for better appearance
