LT1 11:1 compression-octane boost?
Old Feb 4, 2005 | 12:12 AM
Sacredgrooves's Avatar
Sacredgrooves
Default LT1 11:1 compression-octane boost?
i assume a 70 LT1 would need octane boost. what does everyone use and what does it cost you per tank? thanks!
Old Feb 4, 2005 | 03:56 AM
AkMike's Avatar
AkMike
Cruising
That canned octaine boost stuff is "snake oil." Plain and simple. It won't add enough boost to the gas to say so. Don't waste your time or money.
If premium in your area doen't workgood enough then mix 100LL av gas with the high test. I know it's a PITA.. Been there done that.
Old Feb 4, 2005 | 04:22 AM
carl a's Avatar
carl a
this is what i and a few others (larry for sure swears by it) use , i run 1 o.z. per gallon w/93 pump octane to get 101 but do not go thru emmisions testing with it,,lead is banned and i dont know what would happen, i dont care what some guys here on the forum say,,i met the owner of this co at chevy vette fest and seemed like he couldnt believe i even asked him about it and emissions,,you'll have to run -3 -4 ----tanks of unleaded before taking the emissions test--to ''get the led out'' is what he even told me-this is the same lead they took out in the 70's your just puttin it back in-------------http://www.maxlead2000.com/-------------
Old Feb 4, 2005 | 04:45 AM
PRNDL's Avatar
PRNDL
I passed a guy driving an LT1 out of the racetrack one day. He told me he doesn't race the car but stops by the track to fill er up with high octane gas.
Old Feb 4, 2005 | 05:48 AM
Larry B.'s Avatar
Larry B.
You would not believe the difference max lead made. My engine runs noticably cooler, idles better, never pings even under load in fourth gear which was impossible without the lead. Mileage went up by about 3-4 mpg. Plus the nasty eye burning exhaust smelll went away. I highly recommend it in engines made to run leaded fuel. Pre 75 for us.
Old Feb 4, 2005 | 07:53 AM
pws69's Avatar
pws69
You obviously don't know about LeadSupreme......
Old Feb 4, 2005 | 10:05 AM
Lt1er's Avatar
Lt1er
First of all what makes you think that you actually have 11:1 compression? I would like actual piston to deck, piston popup cc and chamber cc.
In the past I had motors that required Morroso 104+ octane booster. But with modern ignitions. (optical & multispark with adjustable vacuum advance) I have driven the last 10 years without a drop of octane boost other than methanol for the drags and I have a true 10.7 compression in my LT1 355 ci
Old Feb 4, 2005 | 10:35 AM
Paul @ Thunder's Avatar
Paul @ Thunder
Before I'd go investing in expensive fuel I would make sure you are truely 11:1 and even then you should be able to get away with 93 octane. you are only a half point over stock. Depending on the cam and tuning 11:1 isn't really that high on an LT1 so I doubt you'll really need anything other then premium fuel. Worst case is you pull a few degrees of timing out and you'll be fine. I daily drive my 99 Z28 with over 12:1 compression on 93 unleaded but I only run about 22 degrees of timing but hey it still make over 450rwhp like that.
Old Feb 4, 2005 | 11:02 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Machtane at www.machtane.com
Old Feb 4, 2005 | 11:31 AM
68/70Vette's Avatar
68/70Vette
I think the article on making your own octane booster is interesting.
http://www.vtr.org/maintain/gasoline-octane.html
At the end of the article is a receipe for making a fuel additive that is supposedly the same/similar to the ones you buy at automobile stores, except instead of $5 for 8 ounces of store bought, you can make your own for a fraction of the cost.
Many years ago I bought av gas for my 11.5:1 Big Block. At first I brought gerry cans to the airport to transport it home. After the guy got to know me, he would pump in right into my car. Neat.
Old Feb 4, 2005 | 11:45 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
If you run the carb on the rich side and retard the timing, you won't need octane boost...
Old Feb 4, 2005 | 11:58 AM
JB's Avatar
JB
St. Jude Contributor
Maxlead works for me. If you have a buddy who works at the local commuter airport (or an airport manager that doesn't care that it's illegal), mixing in blue leaded aviation gas really does the trick nicely as well. But like the others said, drive it, and if you don't get knocking, don't worry about it.
JB
Old Feb 4, 2005 | 01:23 PM
LemansBlue68's Avatar
LemansBlue68
JB
AV gas was the only thing that worked in my '69 Z28. The DZ302 also had 11:1 CR. 94 Octane Sunoco worked to a degree but it still knocked if driven hard and set to best spark timing. My local airport would let me buy the gas in cans but wouldn't let me drive the car to the pumps directly. It's not illegal to fill gas cans with it. It's also not illegal to put leaded fuel into a 1970 car. BTW, you don't have to run the AV gas straight, a 50:50 mix with pump fuel always did the trick for the Z. A bit expensive but that's the price to play.
Old Feb 4, 2005 | 02:29 PM
Sacredgrooves
it is on a car im considering buying. just trying to cover all the bases
thanks for all the advice everyone!
Old Feb 4, 2005 | 02:51 PM
mandm1200's Avatar
mandm1200
Glad to hear the runs on pump gas with 12:1 compression. I was a little worried as the 388 I'm working on is over 11:1 compression.
Old Feb 4, 2005 | 02:58 PM
Paul @ Thunder
Usually we can get by up to about 11.3:1 with 93 pump gas and full timing. It just really depends on you cam selection and tuning.
Paul
Old Feb 4, 2005 | 07:21 PM
grybdn's Avatar
grybdn
the oweners manual for my 71 says to use 91 or higher.
Old Feb 4, 2005 | 07:37 PM
Robert N's Avatar
Robert N
My 70 LT-1 runs on 91. Short of 100 octane, its the best I can get in AZ. My temp needle NEVER gets above 180, even in 100+ temps.
I did just as Oliver suggested above: retuned the car to run a little richer and retarded the timing. I do lose some power, but the car moves quite nicely that it really isn't missed. I can also adjust the jetting and timing and run 100 octane or substitutes like MaxLead and others if I truly want the extra hp.
Old Feb 4, 2005 | 08:45 PM
Emmett's Avatar
Emmett
I mix leadsupreme with 94 and my L89 loves it.
To LT1 11:1 compression-octane boost?
