Changing to comp. spring and strut rods-any tips
Old Feb 4, 2005 | 01:00 AM
jake1's Avatar
jake1
Default Changing to comp. spring and strut rods-any tips
Changing out my steel for comp. rear spring and also puting in new HD strut rods. is there a way to measure ( or do I need to ) the strut setting as it is before I remove all that stuff, so that I have a baseline when the new ones are in and its not terribly off so its drivable for alinment. And any tips on switching out the spring, also bought the 8" bolts. And do you just crank down on those nuts to get the ride height correct?
Old Feb 4, 2005 | 12:06 PM
jake1's Avatar
jake1
Anyone?
Old Feb 4, 2005 | 12:46 PM
FeedVaal's Avatar
FeedVaal
Since the entire geometry is going to change with the addition of new parts, I wouldn't worry too much about where it started. After you get things back together and crank down on those 8 inch bolts to proper ride height then you can eyeball the camber and adjust after its settled.
I set my rear camber by eyeball after spring replacement a year ago and promised I get it aligned but never did. No issues with uneven wear so I quit worrrying about it.
Old Feb 4, 2005 | 02:48 PM
Z-man's Avatar
Z-man
I just took the old ones out and used them to adjust the new ones to approximately the same length (stuck a bolt through each end). To do it right, you'll have to get an alignment anyway - this should be good enough to get you to the alignment shop. Yep - adjust the nuts on the bolts for ride height.
Good luck -
Old Feb 4, 2005 | 02:54 PM
68/70Vette's Avatar
68/70Vette
See today's thread titles "Strut Rod Holes." Yes, use the trailing arm to spring bolt to adjust rear wheel height. The best length for this bolt, in terms of reducing stress/wear on the U-joints is to have the half-axles parallel to the ground. To lower the car you increase the length of the bolt. My 8 inch bolts weren't long enough. I'll be putting on 10" bolts soon.
Old Feb 4, 2005 | 03:12 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
When you install your spring to the rear cover, tighten each of the 4 bolts a little bit at a time. If you run each bolt up all the way, one at a time, you can possibly break on of the ears off the diff cover.
Old Feb 4, 2005 | 03:14 PM
jake1's Avatar
jake1
Thanks, gang.
To Changing to comp. spring and strut rods-any tips
