'76 interior water leak
Old Feb 4, 2005 | 03:41 AM
original76's Avatar
original76
Default '76 interior water leak
Back on this subject. After some investigation, I found where the leak is!!!!! If one takes off the kick panel and looks up throught the large oval holes with a flash light one will see a bead of "caulking" that appears to be sealing the fender from the interior. Two questions, first, I replaced the rubber molding that "seals" between the windshield and fender on the exterior. Should this be siliconed to the window? Secondly, I see no way to run another bead of caulk on the exterior. Can I dry out the area where the bead of caulking is on the interior, with maybe a hair drier, and run another bead over the exsisting caulking? If so, what caulking material should I use?
Old Feb 4, 2005 | 04:45 AM
carl a's Avatar
carl a
that seal was replaced when we did the restoration/body off on my 73 and it never needed silocine or any other sealers, ibelieve this is a ''press fit'' w/downward pressure on the winshilld that keeps water from going thru, your old one was probably uv/age worn
