Wiring Question 1979
Old Feb 5, 2005 | 10:44 AM
BTRNSEX's Avatar
BTRNSEX
Default Wiring Question 1979
Where do you connect the red automatic choke (hot wire). Any help is appreciated
ANYONE???????
Old Feb 5, 2005 | 01:16 PM
Paul L's Avatar
Paul L
You are probably not getting any replies because the 1979 did not have an electric choke. It drew heat from a tube inserted in the intake manifold. Do you have an idea of what carb/choke setup you have?
Old Feb 5, 2005 | 01:19 PM
BTRNSEX's Avatar
BTRNSEX
Paul your correct on manifold heat tubes. I have a edlebrock with electric choke. Any ideas? Someone had a thread on this a few years back. thanks in advance
Old Feb 5, 2005 | 01:25 PM
Paul L's Avatar
Paul L
You need an ignition-switched 12V source. Mine is connected to the ballast resistor but unfortunately you do not have one. Other members have posted in the past re drawing fron the starter, alternator or windshield wiper circuits but I can't recall the details. Hopefully someone will jump in.
Old Feb 5, 2005 | 01:32 PM
BTRNSEX's Avatar
BTRNSEX
Thanks again Paul.....the wiper switch is the one I am looking for. Thanks again
Old Feb 5, 2005 | 01:45 PM
Paul L's Avatar
Paul L
It wasn't the wiper switch itself but a terminal on the wiper motor that is 12V hot when the ignition is on. That will save threading the wire through the firewall to the dashboard switch.
To Wiring Question 1979
