Purchased Steeroids - Have questions.....
Old Feb 5, 2005 | 12:27 PM
73 Vet's Avatar
73 Vet
Default Purchased Steeroids - Have questions.....
Greetings All. I just ordered Steeroids, and am sure I can install without any problems, however, I've got a couple of questions: 1-) did you need to "re-center" the steering wheel? I'm thinking that if I start with the wheel straight-up, I shouldn't need to fool with it. 2-) Any suggestions on setting-up the 2 u-joints and shaft? I have a BB with Hookers.
Any comments are welcome and appreciated.
Old Feb 5, 2005 | 12:41 PM
page62's Avatar
page62
I managed to leave everything centered...and even get away without an alignment (although I should have one done). It's easier than it looks. Just be patient...
Pull your driver's side header. It'll make things go much smoother!
Old Feb 5, 2005 | 02:13 PM
73 Vet's Avatar
73 Vet
Thanks....I've got the engine out of the car now, so should go ok.
Old Feb 5, 2005 | 02:28 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Bah, engine out of the car makes in an hour install. lol
Old Feb 5, 2005 | 02:33 PM
73 Vet's Avatar
73 Vet
:o :o see the red face?....
Old Feb 5, 2005 | 08:43 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i still have to recenter my steering wheel, have not done that yet....make sure when you set up the center heim joint the frame is not flexing..... i had some frame flex that i had to adjust for after i put the engine back in and lowered the car...not a big deal but something i hadn't considered....good luck....if ou have any questions i 'd be happy to tell you how i did it on my 77 350
To Purchased Steeroids - Have questions.....
