Carb Help
Old Feb 5, 2005 | 04:21 PM
matthud's Avatar
matthud
Default Carb Help
I took my car out for a drive the other day, I got it nice and warm, it was about 25 minutes. On my way back home, it stalled when I had my foot on the clutch. Couldnt get it restarted. Had to push it around the corner since I was on a busy road. I had someone else try to start it while I looked down the throat of the carb. When the gas pedal was pushed the gas sprayed down the carb like it was supposed to. But when you let off the gas pedal the gas didnt stop flowing into the carb. After about an hour+ of sitting there letting it cool down, it seemed to be ok, and it started.
I realize now it stalled because it was getting too much fuel. Was this a stuck float or something else? And do you think it was caused by the hot engine temperature?
Its a Qjet on a 69 427.
Old Feb 5, 2005 | 05:40 PM
BigBlockk's Avatar
BigBlockk
Yes it could be a stuck float or you could be getting some fuel percolation going on. This will tend to flood the engine. This ever happen before?
BigBlockk
Later.....
Old Feb 5, 2005 | 05:47 PM
matthud's Avatar
matthud
This was the first time it happened, but it was the first time that I have run the car for about a half hour since I bought it. Every time before it was about 15 minutes, so I thought maybe it was heat related.
Old Feb 5, 2005 | 08:33 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
how are all the fuel lines running ? are they sitting on the intake manifold by any chance?
Old Feb 5, 2005 | 08:39 PM
matthud's Avatar
matthud
No, the metal line is correct in its location.
Old Feb 9, 2005 | 01:31 AM
matthud's Avatar
matthud
Anyone else have some advice on this?
Old Feb 9, 2005 | 05:05 AM
Corvus's Avatar
Corvus
See if the problem happens again, you may want to check fuel lines, then check carb.
To Carb Help
