What da hell is dat???
Old Feb 5, 2005 | 06:31 PM
Musclecarmaniac's Avatar
Musclecarmaniac
Default What da hell is dat???
When installing kick panels (never had the pasanger side) Next to the passenger kick panel speaker hole, I see there is a brass disc looking thingy with a vacuum port. Can I remove this so I don't have to cut the kick panel? And what is it?
Old Feb 5, 2005 | 06:35 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
I believe if I'm remembering correctly that it's a pod that opens & closes the fresh air door. Non-A/C cars do not have this. It also closes the door to keep warmer air out when the A/C is on, opens when the A/C is "OFF".
Old Feb 5, 2005 | 07:24 PM
Paul L's Avatar
Paul L
It's always nice to post the year to get an informed reply.
Old Feb 5, 2005 | 07:27 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Thank God for Borowski, he's out multi-year specialist.
Old Feb 5, 2005 | 07:32 PM
Paul L's Avatar
Paul L
Paul may be but there are differences amongst years.
Old Feb 5, 2005 | 07:46 PM
carl a's Avatar
carl a
paul is correct .its the passenger side kick panel re-circulate door which opens when you put the a/c in'' max air mode''---- at the same time another ones closes-this one is in the wiper well also on the passenger side- which closes off incoming fresh air-now your car is re-circulating cabin air-which will get colder(well its supposed to anyway)-than cooling fresh air---you can watch these work (if you want to) by taking off the kick panel and opening the hood and pull out that screen in the wiper well so you can see that ''flapper'',,, start the car, and have someone sit inside and put the air on,,,,,the have them switch to max air---you'll see that one in the wiper well slam shut----- then try again this time look at the kick panel---start car,, put on air---and put in max air again---this time the kick panel acuator will open-there doing it at the same time cuz theres a ''t'' in the vaccume load off the rotary vaccume switch...which feeds both accuators vaccume when put into max,, iknow this because i had to trouble shoot my entire vaccume system to get my a/c working .the vaccume diagram is the best in the assembly manual for this--- the only thing that was wrong with mine was ''bubba'' pinched a ''source''vaccume line going to the vaccume switch-so nothing was getting vaccume-- he did this while installing the radio!!!
Old Feb 5, 2005 | 07:57 PM
robertmc48's Avatar
robertmc48
Veteran: Marine Corps
Damn...an amazing reply to a post with "Dat".
Old Feb 5, 2005 | 08:29 PM
djcwardog's Avatar
djcwardog
You likely need to match cut your kick panel. I don't have a photo to share from here, but maybe someone can post up a shot for you...
Old Feb 5, 2005 | 08:56 PM
carl a's Avatar
carl a
you either have non a/c kick panels,,or they all come like that and if you have a/c it has to be notched out for the accuator. i just had all this apart again,and went out there and looked. just now.its supposed to go around the accuator-that how they were-when you look down there at the kick panel you see the actuator--with the kick panel cut out going around it-if you want ill go take a picture of mine so you can see it-and ''dats all i gotta say bout dat''-sounds like tony saprano talkin'
Old Feb 6, 2005 | 09:11 AM
carl a's Avatar
carl a
here's the photo of the passenger kick panel,,,,a/c car--- i believe they must all be the same kick panels as far as non a/c and a/c cars,because on my drivers side i have the ''slot'' in it for the vent to open & close and you dont have that ''ball'' or manual vents on a -a/c car--- so i dont need that slot in the kick panel... but thats how there made! ,,," 1 kick panel fits all'' i guess!-----------
Old Mar 2, 2005 | 12:14 AM
Musclecarmaniac
Anybody have more pics? What is a good cutting tool for this? Thanks!
Old Mar 2, 2005 | 12:56 AM
lostpatrolman's Avatar
lostpatrolman
good cutting tool??!! Settle down there bubba. There should be 2 little bolts attaching it somewhere.
Old Mar 2, 2005 | 01:50 AM
carl a's Avatar
carl a
boy what page did you find this post on,!!!! its been a while since i posted replys to it..i took that photo and can tell you its a hard shot to take. its hard to get down there to aim and shoot, but if you want the kick panel on your gonna have to cut to fit----also i dont believe you'll be able to re-locate the diaphram actuator ,because there's a arm that it attaches to to activate the door to close and open,,i know you hate to cut the kick panel,but thats what your supposed to do to install it,,,good luck,,,,carl----------------
Old Mar 2, 2005 | 07:58 PM
Musclecarmaniac
Thanks!
To What da hell is dat???
