Un-rigging my 81'
Old Feb 6, 2005 | 08:46 AM
Bullseye54's Avatar
Bullseye54
Default Un-rigging my 81'
Yesterday I started tearing into my new to me 81'& I can't believe what people can do to a vehicle to rig it instead of fixing it right.All door panels are attached with sheet metal screws along with various other panels & pads.T-tops were superglued together,I already posted on this.The rear window/hatch has a coat hanger for a release cable.The hood release handle is a small pair of vise-grips.Other than that the interior is trashed.When I started it I found timing way off,35* initial,but it started & ran.Then I looked at intake & oil was bubbeling out around bolts,thats when I found that the intake was resealed with RVT,can't see a gasket.You can hear the vac leak,I can't believe this thing runs.So top end comes apart tomorrow.I guess that is why I got it for $3500.On the good side I did sell one of my H-D's yesterday a 53',so I'm going to be paying a visit to Eklers next week to spend it all.......Bob
Old Feb 6, 2005 | 08:53 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you may find those sheet metal screws holding the door panels are not such a bad thing after all......
Old Feb 6, 2005 | 09:04 AM
brooksman9's Avatar
brooksman9
St. Jude Contributor
You think that is bad....one of my valve covers had a crager type lug nut shoved in the pvc gromet to block it off. I first thought, "what kind of valve screws in here". When I got it out I thought, "Oh my god, what else am I going to find"
Old Feb 6, 2005 | 09:13 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
good grief! was the engine leaking pretty good with that plug installed????
Old Feb 6, 2005 | 12:12 PM
redc3's Avatar
redc3
i found sparkplug boots in my floorpan drain holes. thought they were real items at first. oversized bolt in my rear spindle arm holding caliper on, just shoved in there.
Old Feb 6, 2005 | 12:37 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
How about RTV in all exhaust joints to seal leaks.
Old Feb 6, 2005 | 12:47 PM
Pauld's Avatar
Pauld
If it is an '81, it shouldn't even have a rear window/hatch. I think only the 82 collectors edition had those
Old Feb 6, 2005 | 12:57 PM
Bullseye54's Avatar
Bullseye54
As far as the rear hatch goes,supposedly there was a kit to retrofit a hatch possibly Ecklers.The latches are pretty flimsy & it looks like it leakes there also,needs seal also.
Old Feb 6, 2005 | 05:12 PM
81' Corvette Guy's Avatar
81' Corvette Guy
Actually, there are a couple of "original" 81' hatchbacks..late in 81 when the 82's were fixing to come out..the hatch was available through the dealer in late 81. From what I hear from a very reliable source..some of the dealerships added this hatch to a few 81's to enitce my customers to buy 81's that were still on the lot to get ready for incoming inventory. Joe!
To Un-rigging my 81'
