I'm adjusting the timing and
Hi Steve
Your absoulutly right! I guess I was assuming Len already had fan control relays as a part of the Dual Spal Fan wiring setup. Each of the two gray wires on thier wiring harnes switch the primary of each fan relay to ground. Sounded like Len is controlling both fans (via each fan relay) at the same time with one Temp sensor. I choose to control one fan with the temp sensor and the other with a manual switch located inside the cockpit (for emergency hot days) since one fan was typically doing the job.
Bullshark
Hey??? what happened to my Avatar
Never mind it's back
