Strut Rod Question
Old Feb 7, 2005 | 02:15 PM
Edzred72's Avatar
Edzred72
Default Strut Rod Question
I have the larger diameter strut rod ends ('74-'82 1 3/8") on my 72. Just installed poly bushings and there is a good 1/8" space on each side between the mount bracket & bushing. That space also prohibits the proper torque on the camber bolt (CRUSHES BRACKET). The old rubber bushings had bushing caps that fit on each side of the bushing making the rod fit tight in the mounting bracket. Are bushing caps necessary for the poly???
Thanks in advance
Eddie
Old Feb 7, 2005 | 02:19 PM
Twin_Turbo's Avatar
Twin_Turbo
It should be a tight fit, didn't the kit come with washers? What brand is your poly stuff?
Old Feb 7, 2005 | 02:21 PM
mandm1200's Avatar
mandm1200
Looks like you might have answered your own question. I replaced mine with poly and everything I believe was the same except for the type of bushing.
Edzred72's Avatar
Edzred72
Did not come with bushing caps. Bought complete rear poly kit from Vansteel.
Eddie
Vette_Tech's Avatar
Vette_Tech
Yes. The washers are a must.
Old Feb 7, 2005 | 02:24 PM
Twin_Turbo's Avatar
Twin_Turbo
I'm not sure if mine had washers either
Mine look like this (not using them)....I think they need washers
Old Feb 7, 2005 | 02:30 PM
Edzred72's Avatar
Edzred72
Just when I thought I was done. Arrrrggg....now where did I put that parts catalog.
Thanks guys
Eddie
Old Feb 7, 2005 | 02:50 PM
Fevre's Avatar
Fevre
Thanks guys
Eddie
Eddie
Give VanSteel a call or e-mail, they should send you some if they where left out of the kit.
Chris
Old Feb 7, 2005 | 03:05 PM
Edzred72's Avatar
Edzred72
Originally Posted by Fevre
Eddie
Chris
Old Feb 7, 2005 | 03:10 PM
fmann87's Avatar
fmann87
7th Gear
I got my poly bushings from PST. I had to reuse my old washers. Everything fit perfectly.
Old Feb 7, 2005 | 04:05 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Eddie
Chris
He just got a poly conversion kit and they are not included. Your supposed to reuse your old washers.
Ed - you have mail.
Old Feb 7, 2005 | 04:55 PM
Edzred72's Avatar
Edzred72
Ed - you have mail.
Quick response and GREAT customer service...Thanks Vansteel!!!
P.S. Old washers were rusted & shot. Thought poly bushings didn't require washers. Everyday's a learning day.
Eddie
Old Feb 7, 2005 | 05:06 PM
Fevre's Avatar
Fevre
Knew they would give you a quick service, even if it was not what you wanted to hear.
Old Feb 7, 2005 | 05:23 PM
GTR1999's Avatar
GTR1999
Eddie since you have the rear suspension up in the air look at the bearing support where the larger strut rods fit. Sometimes,not all the time, the larger head may bind under extreme travel. Look for any marks that would show this. You can slightly modify the support so that doesn't happen. I milled a small radius in mine when I was rebuilding the T arms and rear bearings but a file will do if you need to.
It's not uncommon to find the larger head rods in the older cars as they were the service replacement part.
Gary
Old Feb 7, 2005 | 11:05 PM
Edzred72's Avatar
Edzred72
Originally Posted by gtr1999
Eddie since you have the rear suspension up in the air look at the bearing support where the larger strut rods fit.Gary
Thanks for the heads up Gary...the bearing support was fine. Everything but the half shafts is installed, (spicers going in) but I'll have to remove the strut mount bracket to get those bush washers installed when they come. THEN...I'll post pics of the finished product. Don't worry...I'll make ya proud.
Eddie
To Strut Rod Question
