Approx CR needed
Old Feb 7, 2005 | 05:32 PM
GTR1999's Avatar
GTR1999
Default Approx CR needed
355 with 4 relief flat tops and 67cc heads, I'm guessing about 9.5:1??
Anyone know for sure?
Thank you,
Gary
Old Feb 7, 2005 | 05:34 PM
Gordonm's Avatar
Gordonm
You wouldreally need to know where it is in the hole. Is it a zero deck height or how many thousandths down. I would suspect around 9.5 to 1 but to be exact you would need that info.
Old Feb 7, 2005 | 07:05 PM
mandm1200's Avatar
mandm1200
Just with some rough numbers I would guess closer to 8.9 :1.
I figured with a .030 bore, .043 head gasket, piston to deck height of .025, 67cc heads, and 10cc for the pistons.
To get closer to 9.5 to 1 you would have to reduce the quench area by about .025". Or you could drop the cc of the heads to 64 and get pistons with 2 reliefs.
Old Feb 8, 2005 | 12:11 PM
Matt Gruber's Avatar
Matt Gruber
Thank you,
Gary
with .040 quench 9.7:1
But my guess is it's not decked, and has a thick HG, 9.1:1 + or- 1/4
Old Feb 8, 2005 | 02:03 PM
kcmk's Avatar
kcmk
Gtr, more info is needed to get it exact. Here are a couple of calculators I have used to figure, first the piston deck clearance, and then with that info you can figure the static CR.
http://www.kb-silvolite.com/calc.php?action=deck (deck clearance)
http://www.csgnetwork.com/compcalc.html (compression ratio)
StingrayDK's Avatar
StingrayDK
http://www.kb-silvolite.com/calc.php?action=comp
Damnit, you beat me to it
Old Feb 8, 2005 | 02:08 PM
kcmk's Avatar
kcmk
Originally Posted by StingrayDK
You know the old saying..."First one to the trough...". But I did leave you a "floaty"!
Old Feb 8, 2005 | 05:21 PM
GTR1999's Avatar
GTR1999
Thanks guys. This is an original non machined block. I will be using the thick FEL-PRO's, flat tops, and have no idea of the depth-didn't check it before pulling apart the engine. I was going to use the stock cast pistons but have decided to bore it so I'll go with the cast FT's and moly rings. I want to keep it within 9-9.5 max I was planning on the 260H cam with the stock 8.5 CR and didn't know how much the higher CR might affect the cam choice?
Gary
Old Feb 8, 2005 | 05:27 PM
joe73vette's Avatar
joe73vette
Those cast 4-relief pistons are about 6cc. I measured mine. Joe
Old Feb 8, 2005 | 06:05 PM
kcmk's Avatar
kcmk
Assuming all of the following:
Bore: 4.030
Stroke: 3.480
Gasket Bore Diam.: 4.166 (Fel-Pro Steel)
Gasket Thickness: .041 (compressed)
Chamber Volume: 67cc (big assumption)
Piston Dome Volume: -6cc
Piston Deck Clearance: .026 in the hole (another big assumption)
It calculates out to 9.30:1. By milling the heads to achieve a 65cc chamber, you would be at exactly 9.50:1.
Old Feb 8, 2005 | 08:54 PM
GTR1999's Avatar
GTR1999
Bore: 4.030
Stroke: 3.480
Thank you for taking the time to figure this out for me
The heads are WP S/R Torquers and that was their published size. I didn't measure to see how acurate they are as it's not that important to me. Sounds like I'll be in the 9-9.5 range I wanted so that's good.
Gary
Old Feb 9, 2005 | 06:57 AM
Matt Gruber
i have a similar set-up.
where do u intend to shift?
268H is better if over 5200.
i shift 5700 w/xe262
Old Feb 9, 2005 | 08:08 AM
GTR1999's Avatar
GTR1999
Hi Matt,
I thought about the 268 but this isn't a road rocket car. I doubt I'll be pushing past 5500 much if at all- th400 w 308 gears. The 260 seems to be the right fit. I just wasn't sure if the increased CR would play into it, but looking at the comp catalog last night I see those cams are for 8 -10:1 CR. I think the 260 will produce a little more lower end where this will run.
Next I'm looking at torque convertors. Was thinking of the 2000 stall B&M but Comp has their own line and has one in the 1800 range.
Gary
Old Feb 9, 2005 | 08:51 AM
kcmk's Avatar
kcmk
Gary
Glad to do it. Good luck.
Old Feb 9, 2005 | 11:11 AM
Matt Gruber
Gary
did u know stock 72 stall is 2100?
260H good w/308(move the kickdown switch to 1/2 throttle and it will LEAP!
SEE MY HOMEPAGE FOR MORE TIPS),
but i'm not sure if u can get away with 87 octane as i do.
Old Feb 9, 2005 | 12:01 PM
GTR1999's Avatar
GTR1999
Matt no I was never able to find the 72 vette stall rating anywhere. From what others have said here I thought it was around 1500-1600??
Where did you find the information at?
Thank you,
Gary
Old Feb 9, 2005 | 12:12 PM
Matt Gruber
Thank you,
Gary
was in the free GM spec's(call chevy toll free)
a 2500 stall would do the trick imo.
Old Feb 9, 2005 | 12:13 PM
mandm1200's Avatar
mandm1200
I have never seen published stall rating for the C3 or GM. When a cam manufactures says to use a stall speed 500rpm over stock it's just a guess as to what stock is. I believe since the stall speed varies with the torque of the engine, it's just a shot in the dark anyway. From my understanding the 1500-1600 seems about right.
Old Feb 9, 2005 | 12:51 PM
Matt Gruber
1-800-222-1020
page 15 of the power train section
stall
2110
anyone who does not have this free spec&resto kit is not playing with a full deck
To Approx CR needed
