speedometer gear removal
Old Feb 7, 2005 | 05:40 PM
painterman52's Avatar
painterman52
Default speedometer gear removal
I put 370`s in my 75 and of course this screws up the speedometer reading. after a little research I figure I need a gear with 2 more teeth. So I start to remove the old one. I removed the keeper & started to pull out the housing when trans fluid began leaking I put it back. How do you get this out without losing all the fluid?
Old Feb 7, 2005 | 06:52 PM
gh78's Avatar
gh78
My son changed it in my 78. just put a small pan uner tranny and catch fluid. you won't lose much.
Old Feb 7, 2005 | 06:58 PM
Retro78's Avatar
Retro78
Just did this last week.
Old Feb 7, 2005 | 07:24 PM
john1977's Avatar
john1977
Did that a couple of month ago, very little fluid back there.My hardest part was getting the driven gear off the shaft. Everything is easier if you drop your cross member.
To speedometer gear removal
