Starter Type and Recommendation
Old Feb 7, 2005 | 08:48 PM
glen242's Avatar
glen242
Default Starter Type and Recommendation
While removing the thin wire from my starter solenoid, I managed to break the terminal. New solenoid is about $30 locally, so I started thinking about replacing the 28 year old starter with a mini. My old block was drilled and tapped for both the straight and staggered starter bolt holes. Original is staggered. New block is tapped for staggered holes only.
No, I am not about to drill and tap my new block, so I need a recommendation for where to get a new tech starter with staggered holes.
Thanks,
P.S. - So much for my economical upgrade! The more I do, the greater the cost. At this rate, I will have about 50% more into this than I figured. You know, while I was in there...
Old Feb 16, 2005 | 07:53 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
ttt
Old Feb 16, 2005 | 07:58 PM
Jack71's Avatar
Jack71
I have a CSI w/ staggered holes that I purchased from Summit. Great so far!
LFZ's Avatar
LFZ
Powermaster or Summit make mini starters for the staggered bolt pattern...they usually cost about $50+ more though.
Old Feb 17, 2005 | 12:27 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I like the Delco mini starter that resembles a small stock starter. There have been several threads discussing it. Mine was quite a bit more than a stock starter, but no more heat soak!
Old Feb 17, 2005 | 12:54 AM
ferndog4's Avatar
ferndog4
I just bought a starter for 85 corvette, its a gear reduction type unit. Find a rebuilt its much less than what you get via mailorder and bolts right up. oops, dont think its staggard.
Old Feb 17, 2005 | 09:08 AM
68BLUEVETTE's Avatar
68BLUEVETTE
where is moon TWP PA?
I have a big block starter that is spare, not the mini, but I would let go of it cheap. I also have just a solenoid if you would like. Heck, I even have just the solenoid cap I would give to you for free if you wanted to pick it up.
I was chasing electrical demons, so that meant buy 3 spare starters....
Old Feb 17, 2005 | 09:34 AM
Stewart's74's Avatar
Stewart's74
I'm no expert on starters but.....
I bought a Powermaster Mini starter on e-bay. It has a staggered bolt pattern and fits a 168 tooth flexplate.
It works like a champ.
Old Feb 19, 2005 | 02:44 AM
glen242's Avatar
glen242
Moon Twp. is near the Pittsburgh airport. Thanks for the offer, but I want a mini starter.
To Starter Type and Recommendation
