tank sticker
Old Feb 7, 2005 | 10:06 PM
71redskin's Avatar
71redskin
Default tank sticker
undefinedi am the third or fourth owner of a 71 LS5... what are the chances that the tank sticker would still be on the car....i have felt on top of the gas tank but don't feel anything that would indicate its presence...your poinions would go a long way as to whether i drop the tank...doesn't look like a very hard job
Old Feb 7, 2005 | 10:37 PM
etech152's Avatar
etech152
IMHO, one thing I'd check is "IF" you have the original Gas tank in your 71 Corvette. If so, then go at it. But many C3's have had new Gas Tank installs due to leakage and the gas tank replacements are so cheap compared to a repair.
Old Feb 7, 2005 | 11:29 PM
copter's Avatar
copter
I've heard that you can get to your tank sticker(At least see if it's there)by taking off your gas filler top and taking a peak down in there.
Old Feb 8, 2005 | 12:42 AM
mstanton's Avatar
mstanton
Depending on where it was placed you may be able to see it by removing the rubber boot around your fuel tank neck. I was able to see and remove the tank sticker on my 70 by doing that. The "feel" method is not reliable because of the 30+ years of dirt that would be on the sticker. On my 71 I have done everything short of dropping the tank and have not found a sticker. GOOD LUCK
Old Feb 8, 2005 | 09:55 AM
Paul @ Thunder's Avatar
Paul @ Thunder
I did a tank replacement 2 weeks ago on my '69 and there was no tank sticker. Can't really say if the tank had been replaced before but it was an original with the logo and all. It did have a sticker on the bottom side of the tank with a dealership name and address in OR. I sure was hoping it would have been there.
Old Feb 8, 2005 | 11:18 AM
stingray4me's Avatar
stingray4me
here is how I dropped the tank & some other web sites I made up too.
http://www.corvetteclubcentralga.org...embersproj.htm
To tank sticker
