this pic will show you a couple good products you can get at Walmart.
The Shoe Goo is for big holes & the Permatex Vinyl repair kit is for smaller holes. If you take your time you will get a good result.
A "close" paint match for your car would be SEM Landau Black, some automotive paint supply houses have it or you can get it here. http://www.levineautoparts.com/semvinandpla.html
Thanks for taking time to help me out Ed T. I do appreciate it!
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Best,
James1970
i have used the permatex kit....the shelf life is like zero, (well maybe longer then that but not long).... after you open the "filler" so get all your stuff ready to do at once.....
Small holes can just be filled. Larger cracks need to be mechanically fastened by gluing a backing such as plastic behind the crack before filling. I also use the leatherique dye. I airbrush it on but it can also be applied with a brush.
Good luck with your repairs.
David
Thanks for the information David! The Leatherique product is interesting.
david and i have posted many photos of the dash and interior repairs right around christmas time-you should do a search,,for there was a lot of good info we both posted.also that kit you have from wallmart,,,i tried it and it failed,i got a freah kit delivered to me from permatex and it also failed-go with the leatherique and look for all the photos we posted-good luck-carl
I just finished repairing and re-dying my 78 door panels. I used the SEM Landaua Black and it came out awesome. I would also recommend the other components of the SEM system, Vinyl Prep, etc.
I had doubts about doing such a large area from a can, but the results are impressive and I was able to dye my door panel carpet with the stuff as well with very good results.
