coil-over compressed length
Old Feb 8, 2005 | 09:39 PM
DaveL82's Avatar
DaveL82
Default coil-over compressed length
I started a thread a few weeks back about my coil-over setup for the 80 aluminum diff car.
One of my issues is finding a short enough shock without spending an arm and a leg and one valve for roadracing not drags. I have a pair of Bilstein S6M-3050 which have a 13 inch compressed length including rod ends. Based on that this means I need to move the upper shock mount inside the rear frame so I can move it up as much as possible instead of mouning on the bottom flat of the frame.
I now have to locate the lower mount about 7 inches below the rear of the trailing arm to allow the rear suspension to compress without bottoming the shock.
Oh well more to follow as this progresses (slowly).
dave
Old Feb 8, 2005 | 09:52 PM
norvalwilhelm's Avatar
norvalwilhelm
I used 5 inch travel shocks that were about 15 inches extended and 10 inches compressed and was able to use the stock upper shock mount. I did make a billet shock mount instead of the sheet metal one that is stock but it is in the stock location.
The 5 inch shock travel gave me 7 inches at the wheel.
Old Feb 9, 2005 | 07:31 AM
DaveL82's Avatar
DaveL82
Norval - I did find a few shorter shocks but they aren't many. I needed somehting that was a more common length so I can swap them out easy for other brands or valving changes.
The Bilsteins are very reasonable so I suppose I'll just fab the mount to fit the 13 inch compressed length.
Shocks $70 ea
Coil over kit $36 ea (threaded lower adjuster and upper spring retainer)
springs $56 ea
cost of mounts when done $100 per side
Old Feb 9, 2005 | 12:55 PM
norvalwilhelm
I paid $715 per set or $1430 for 4 plus about another $1000 for springs for testing.
To coil-over compressed length
